What micron barrel screen? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 5 Old 04-10-2014, 10:59 PM Thread Starter
Woodturner Nate's Avatar
Quoted: 2 Post(s)
So I have to replace the screen prefilter in my settling barrel; I was given one that is plastic, and starting to tear, plus it's just nasty and full of poly. What micron size do y'all use? There's a few people selling them on Ebay, 150 & 400 micron seem to be the common sizes. I have absolutely no idea what I have now. The ones I'm looking at are: WVO Drum Filter Used Cooking Oil Basket Biodiesel Filter VEG Oil Strainer 150MIC | eBay
It's worth $80 to me to not have to do it myself. I am not a great welder, and by the time I got some galvanized steel into a decent circle, and bought stainless mesh, I'd rather pay someone to do it.
Any recommendations?
2007 F350 King Ranch CCLB 4x4
WVO conversion in planning
RIP 1996 F250 eclb, 4x4, 7.3L PS
Viair 444C/6g air tank on frame, Hadley air horn, Hella auxiliary reverse light, DIY WVO conversion; Efuel, dual FuelLab FPR's, 90g RDS tank, aluminum tube-in-heater hose, hotfox heated fuel pickup, copper coil-wrapped filter, 40-plate FPHE, auxiliary coolant pump, 2000lb winch-crane bolted to the frame. Ranch hand front bumper. Big winch.
Woodturner Nate is offline
post #2 of 5 Old 04-11-2014, 10:38 AM
timmyboy76's Avatar
i used the plastic ones...200/100 microns stacked. That was until the first cleanig of them. Whatta mess. Used a kiddie-pool and dish-soap.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 5 Old 04-12-2014, 03:06 AM
simone0414's Avatar
All I need to do is get the big chunks out so I have always used window screen. I just took some 1"x3" strapping & built a frame & attached the window screen to it. When It starts to plug up with crap I just take it to the edge of my property & whack it on the side of a tree & its ready to go again. I know its no wheres near the micron rating of what you have posted but for me it works. Cost me about 5 bucks to make.
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #4 of 5 Old 04-13-2014, 06:50 PM
timmyboy76's Avatar
me too, simone, but i doubled up the screen. From there, i run it through a shirt, then into my 55gal drum barrel to begin filtering and cf-ing.
1st time cleaning them barrel filterswas enough for me.
post #5 of 5 Old 04-17-2014, 07:43 AM
Same thing here except I cleaned them twice, after the second cleaning I bagged it.
I have a metal kitchen strainer wrapped over a foot valve on my 1" cubie stinger and that suffices for me. Never has to be cleaned.
MtnOil
2005 Excursion 6.0l Eddie Bauer, 175k
MtnOilRIG is offline
