filtered used motor oil blend use, how long, which engines - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
 1Likes
post #1 of 15 Old 03-05-2014, 09:10 AM Thread Starter
bfloyd4445's Avatar
Quoted: 3 Post(s)
not talking about bio d but filtered used motor oil, and other oils used as fuel. I'm curious as to if this really works without messing up your engine. So, if your using a blend what is the blend, how often do you use it, how long have you used it and which engine and its modifications do you run it in.
I heard some of the really old engines will burn just about any oil without problems if filtered.
thanks
Britt
2007 F250 CC SB 4X4, SB, PSD, Lariet, stock
1975 Ford 2000 ROP Diesel tractor < ran without oil for 2/10 mile 7/12/2009> Stills runs as good as ever
"If you don't read the newspaper you are uninformed,
If you do read the newspaper you are misinformed."
-Mark Twain
bfloyd4445 is offline
post #2 of 15 Old 03-05-2014, 03:56 PM
simone0414's Avatar
Does it work?? Depends on who you talk to.
It has been run in alot of 7.3's with varying degree's of success. I have read of some running it 6.0's but that's really taking some chances. Older Mercedes engines & mechanically injected Cummins will run most anything. Wouldn't suggest any Chev engine other then maybe a 6.2.
I have never run it myself but have talked to alot of guys that have & the most important thing is filter, filter & filter some more. When I say filter I mean with a centrifuge. Spin on filters alone will not get WMO clean enough.
Also it seems that if you run any more the 50% WMO you will eventually ( probably sooner then later) run into your truck smoking excessively, hard starting in cold temps, loss of power due to injector coking.
IMHO the best chance of success is to run a heated 2 tank system & start & stop on D2. You could still have problems running it that way though.
With the cost of D2 where it is now though if all I could get my hands on was WMO I would run it.
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #3 of 15 Old 03-05-2014, 06:40 PM Thread Starter
bfloyd4445's Avatar
Quoted: 3 Post(s)
I think I've heard talk of the first strokes running filtered oil but never seen one. I think any of them will need injector service more often at the least
Britt
-Mark Twain
post #4 of 15 Old 03-05-2014, 07:03 PM
nathan's Avatar
I ran wmo and wvo oil in my 7.3 without any problems in the summer and spring months. I have been running both in my 6.0 for about 4 months without any issues as well. Since the temps have dipped below 40 degrees I have only ran d2 for the past 2-3 months. I get used motor oil store it in a 55 gal drum and let it sit for about a week. Pump it out of the drum through a 30 micron filter into another tank before going through a heated centrifuge twice at 225 degrees. It is then pumped out of a storage tank through a 10 micron filter into my truck. I mix at about 50% and still have a noticable smoke and odor at idle. I have never had any injector or fuel filter issues because of running the wmo. I still change my filters every 10,000 miles same as when I ran straight d2. I drive mostly highway at speeds at or near 80. I dont let the truck sit and idle for long periods of time whick can lead to coking of the injector tips. Just my 2 cents and experiances with wmo.
[/SIGPIC]
99 superduty crew cab 4x4
95 f250 4x4
91 ID IBronco Centurion (rough) but only 895 miles
86 IDI f250 4x4 (just bought)
2000 custom bike I built
nathan is offline
post #5 of 15 Old 03-06-2014, 04:56 PM Thread Starter
bfloyd4445's Avatar
Quoted: 3 Post(s)
do you use any fuel additive?
Thanks for the info Nathan
post #6 of 15 Old 04-25-2014, 06:00 AM
JonnyArch is offline
post #7 of 15 Old 04-25-2014, 06:41 AM
Term3's Avatar
I've seen three engines ('89 7.3 '04 6.0 and a 12 valve Cummings) overhauled that ran on a high ratio mixture of lube oil and diesel. The coke buildup on the rings and exhaust valves was shocking.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #8 of 15 Old 04-25-2014, 12:29 PM Thread Starter
bfloyd4445's Avatar
Quoted: 3 Post(s)
you don't happen to have any pictures of them do you? I would love to see what they looked like
Britt
-Mark Twain
post #9 of 15 Old 04-25-2014, 01:12 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
A water injection kit would have likely cured that.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #10 of 15 Old 04-25-2014, 01:33 PM
simone0414's Avatar
There is a couple guys on the TDS running WMO(W85) & experimenting with WI. Their results was not so promising. Still have excessive smoke & coking injectors. WI can't hurt but it doesn't appear to completely eliminate the problem. There is one guy that claims propane injection has completely cured his smoking/coking issue.
Short of cracking it into D2 I expect that there will always be problems with running high % amounts of WMO.
Tags
filtered oil , oil blend , waste oil use
