Bio Diesel Benefits - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
 2Likes
post #1 of 14 Old 03-03-2014, 08:31 PM Thread Starter
Bio Diesel Benefits
Are there any benefits to running biodiesel from the pump? What concentrations serve the trucks best? B5, B20, B50, B100?
2005 Ford F-250 CCSB Lariat FX4
OEM Heads, OEM Head Gaskets, ARP Head Studs, Sinister EGR Cooler, Upgrade OEM Oil Cooler, Blue Spring Update, Sinister Coolant Filter System, STC Fitting, Turbo Drain Tube Upgrade, Innovative Diesel Xtreme Street Tune, Magna Flow Exhaust, FICM Ultra Service by FICMrepair.com, PHP FICM Eco Tune, High Idle Mod, 2.5" Leveling Kit, 34" BF Goodrich A/T, A-Pillar (FP, EOT, EGT), and Engine Link Monitoring
cfree5119 is offline
post #2 of 14 Old 03-04-2014, 02:17 AM
Quoted: 3 Post(s)
environment and thats about it
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #3 of 14 Old 03-04-2014, 02:55 AM
I used to get B20 when I was on my 600 mile trips to TN. I actually liked it, because it made the truck run smoother (much more cetane rating). One thing is to make sure to change your fuel filter on a regular basis. Many people complain about Biodiesel, but often people don't understand you can't just poor vegetable oil down the truck. You have to get the glycerin out of the oil. Glycerin is what mainly clogs up the fuel system. Correctly made biodiesel is actually a great cleaner it removes gunk and deposit in the tank. This is why you have to change the fuel filter a couple of times when you start running biodiesel.
00 Excursion 7.3 (1.0 Ex. hsng., 3.5" downpipe, Aero Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, HPX, IAH delete, DP- Tuner F6, Riffraff Boost Fooler, Melling Oil Pump), Fuel lab 41402 pump and regulator, fuel bowl delete, 910 Comp Springs/Shims, DI Pushrods, Swamps HVHF IDM, SRP 1.1 HPOP Dieselsite trans and coolant filter, 203* thermostat, Sonnax valve 0.427 and tricumulator springs, Lift, MM Hubs, 35's and 3.73s, 08 diff cover, Hellwig rr. bar
326RWHP @ 731RWTQ.
572ysc is offline
post #4 of 14 Old 03-04-2014, 01:50 PM
And financial if you produce it yourself
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #5 of 14 Old 03-04-2014, 02:34 PM
One thing I would do if you do plan to run biodiesel is to do a regulated return aftermarket fuel pump and run two spin on filters to ensure your engine is getting clean diesel.
326RWHP @ 731RWTQ.
572ysc is offline
post #6 of 14 Old 03-04-2014, 07:25 PM
Interesting. Please elaborate....
I can't think of any benefit to the above suggestion. Please, enlighten me.
99 F350 7.3
B100 by Biopro 190
post #7 of 14 Old 03-04-2014, 07:32 PM
Well,
when you go to a regulated return and aftermarket filteration/fuel pump. You are first getting rid of dead heading the #8 injector. In addition the spin on filters carry more filter volume over the stock filter, while having a better micron rating. On my setup, I am running a 2 micron post filter. (Less likely to clog up). Also, filters are cheaper when converting to a spin on setup.
326RWHP @ 731RWTQ.
572ysc is offline
post #8 of 14 Old 03-05-2014, 03:47 AM
Well,
That is good advice for any PSD, however, it if far from required to effectively burn biodiesel at any ratio. In fact, ASTM biodiesel is produced at a tighter spec than pump D2 in respect to water content and particulate contamination. Those with a fear of filter obstruction from burning ratios of biodiesel is generally unfounded when ASTM fuel quality standards are met, after the introductory period. The need to run myltiple filters, carry several extra filters for daily driving in basically just an Urban Myth if you will.
Biodiesel is a great detergent. It will remove accumulated algae and contaminates from your tank and lines which is normal to all diesel vehicles. What most find when their vehicle is introduced to biodiesel is a positive cleaning effect. Many recomend a B50 blend on the first tank full, then increase the ratio on second and third fill ups. It may be required that the stock filter be changed between the first and third tank, but from then on it is normaly to have trouble free driving from that point forward.
To summarize, Biodiesel users may experience filter obstruction in the first three tanks, and this generally is considered a positive effect. Significant fuel system modification (in operation temps above 32"F) is certainly not required or necessary and should not be done solely for the purpose of burning biodiesel, rather for performance or convience. The above applies to operation temps where biodiesel is practical.
Bear 1 likes this.
99 F350 7.3
B100 by Biopro 190
post #9 of 14 Old 03-05-2014, 06:05 AM
Thats right I agree with. Just firgured it would be a good combo to run. Yes, as long as your biodiesel is produced correctly, it is better than regular diesel in my opinion. Many people just seem to believe that you can poor in whatever.
326RWHP @ 731RWTQ.
572ysc is offline
post #10 of 14 Old 03-05-2014, 06:25 AM
Quoted: 3 Post(s)
thats because in a 7.3 you pretty much can
Vegistroke V3.
