Custom alum. veggie tank done! - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 8 Old 11-05-2008, 10:48 AM Thread Starter
Cark's Avatar
Send a message via AIM to Cark
Just got back from my welder and picking up my veggie tank I had them build. All the fittings and holes for my return lines and sending unit and hot fox... time to plumb and install!
It's about 41 gallons and going to fit under the bed between the frame rails, totally clean, you won't even know it's there without looking under the truck.
'03 SAAB 9-5 Aero Wagon 5-spd - Stg 1
95 350 Crew long box - Sold
Cark is offline
post #2 of 8 Old 11-05-2008, 11:03 AM
NICE!! great forward thinking
korterman1 is offline
post #3 of 8 Old 11-05-2008, 11:21 AM
Drepka's Avatar
Send a message via Yahoo to Drepka
Looks great.
Traded in the 00'
TW 6 pos. chip......reinstalled
Isspro gauges.....Finally in 04-27-09
DIY Tymar.....04-21-09
Zoodad.........04-22-09
Foil delete.....04-22-09
next:
Leveling kit--delayed-wife totalled new car!!!!!!!!!!
4" turbo back MBRP....installed !
305/70/16 Goodyear Wrangler Silent Armors-- done yesterday
Drepka is offline
post #4 of 8 Old 11-05-2008, 11:25 AM Thread Starter
Cark's Avatar
thanks guys! I can't stop peaking over at it and grinning. I'm really excited about this whole project starting to come together.
Cark is offline
post #5 of 8 Old 11-05-2008, 11:38 AM
Lonno's Avatar
Above the driveshaft? Seems like a tight fit.
1970 F250 Crew Cab rebuilt/restored w/Cummin s 4bt
8v, M5R2 Tranny, VE pump, DennyT stage 2 pin, M&H Dynamic Timing, 3200k gov spring, Hx30/Hx35 Twins, 40hp styx, smoke screw screwed, star wheel cranked, Hydroboosted
91 Gillig Phantom, Converted transit bus, 6v92 Detroit Diesel
6500 Watt Diesel Generator on board
All Diesel
All Day
Lonno is offline
post #6 of 8 Old 11-05-2008, 11:39 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
i don't see any hanger tabs welded to it?
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #7 of 8 Old 11-05-2008, 12:29 PM Thread Starter
Cark's Avatar
not above the driveshafts, behind the rear axle (mine is a long bed). You're right CHenry, no mounting tabs welded to it. I'm going to wait until I get my fittings and hot fox and sender all mounted then bring it back to have some straps made. You don't want to weld tabs to the aluminum because over time they'll weaken and eventually you're nice tank will end up on the ground :-(
Cark is offline
post #8 of 8 Old 11-06-2008, 08:41 AM
I agree.
Use some straps Excursion style and you'll be good to go for many miles...
2005 Excursion 6.0l
wilson & Co is offline
