Any TDI owners ? Im looking for a tank - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
 1Likes
post #1 of 15 Old 02-12-2014, 01:56 PM Thread Starter
Quoted: 3 Post(s)
so I have an 03 jetta wagon. I am looking to convert later this year when I move back to CONUS. I have everything for conversion except tank. Since I have a wagon I would like to put tank underneath the car. Is this even possible? Any idea who could make a custom tank? Prefer tank to be at least 10 gallons and I would have a custom panel made so I can fill from outside of car.
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #2 of 15 Old 02-18-2014, 03:55 PM
VeggieDoug's Avatar
TDI tank
I have an extra one that was made by Greasecar.com. It's a 13 or 14 gallon tank that goes in the spare tire area. It has the heating element in it, but doesn't have the fuel level gauge or the cap. It would be shipped from Florida, zip 34654.
VeggieDoug is offline
post #3 of 15 Old 02-26-2014, 12:30 AM Thread Starter
Quoted: 3 Post(s)
can you pm me price and pictures if you have them? I will need it shipped to 32792 which is winter park.
Vegistroke V3.
post #4 of 15 Old 06-16-2014, 10:43 AM
20 gallon veg tank
FYI, I have a custom tank that was designed for my 03 TDI wagon. It was in the back driver side, the plastic and spare cover were modified so the tank could sit on the metal using metal straps to hold it down. I have since removed the system. (Plantdrive system, vormax filter, hotfox, vegtherm inline heater)
Top view of tank
End view of hotfox
onedesign is offline
post #5 of 15 Old 06-16-2014, 12:11 PM Thread Starter
Quoted: 3 Post(s)
any pictures of it installed? How much are you selling it for?
Vegistroke V3.
post #6 of 15 Old 06-17-2014, 09:46 AM
Tank installed
$400 for tank and hot fox. OBO
I attached an image using my phone. If it doesn't work I'll upload one a bit later.
post #7 of 15 Old 06-24-2014, 12:31 AM Thread Starter
Quoted: 3 Post(s)
thanks for reply but i need something hidden
Vegistroke V3.
post #8 of 15 Old 08-01-2014, 08:45 PM
Woodturner Nate's Avatar
Quoted: 2 Post(s)
Wondering if you ever found a reasonably priced tank? I'm thinking about converting my newly-acquired '03 TDI. Greasecar has a 13-gallon tank that fits in the spare-tire location, but it's $600!!!! I paid $700 for a NINETY gallon tank for my Powerstroke. I realize that it's hard to make a round tank and all, but there's a quarter the number of welds, and less than a quarter the material than in the big tank. Lot of $$$ for a car that gets 50mpg already. Tough to swallow that one.
2007 F350 King Ranch CCLB 4x4
WVO conversion in planning
RIP 1996 F250 eclb, 4x4, 7.3L PS
Viair 444C/6g air tank on frame, Hadley air horn, Hella auxiliary reverse light, DIY WVO conversion; Efuel, dual FuelLab FPR's, 90g RDS tank, aluminum tube-in-heater hose, hotfox heated fuel pickup, copper coil-wrapped filter, 40-plate FPHE, auxiliary coolant pump, 2000lb winch-crane bolted to the frame. Ranch hand front bumper. Big winch.
Woodturner Nate is offline
post #9 of 15 Old 08-04-2014, 02:59 PM
If you think the tanks for TDI's are expensive, wait until you are replacing IP's on a regular basis from WVO use. I'm sure glad I got WVO out of my systems. I put three pumps into the 02 until I switched to B100.
Woodturner Nate likes this.
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #10 of 15 Old 08-04-2014, 05:03 PM
VeggieDoug's Avatar
I have had no problems running WVO for the past 4 yrs. I de-water, heat to 190-200, then centifuge at 4gal per hour. The oil that goes into my vehicles is clear enough to fry Thanksgiving turkeys in if I wanted to. IP failures are due to operator neglect to properly purging the system prior to shut down.
The Following User Says Thank You to VeggieDoug For This Useful Post:
P&W4000 (08-13-2014)
