| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
wvo supplements
I know i have been told to put killem in my wvo when i store it but i might not be able to get that stuff in my town. I might be able to get that power service stuff bio kleen, anyone ever use it? how good is it?
i haven't seen bio-kleen or killem, but how long are you storing wvo?
i let my 20 litre cubies sit for around a month or so and then i filter it it into 200liter plastic barrels. i figure the filtered oil will be in their for around 2 to 3 months before its all used up.
2-3 months should be ok. Just take a sniff and see if it smells like used oil or rancid rotting dog crap. if it smells ok, I would not worry. I have some oil sitting in barrels now for about 6 months and after 4 it still smelled ok, but i added some biokleen to it just to be safe.
If your stored oil is bone dry (passes the hot pan test with zero bubbles) you are much better off than having a layer coffee cream (wet oil) at the bottom. It's the wet oil that turns rancid. Two or three months is not a long period of storage. Killem is almost impossible to find locally. I ordered mine through FryerToFuelDotCom. Put a drain valve at the bottom of your 200 liter barrel to drain off any settled sediment and coffee cream that may not have been removed prior.
