new wvo heater - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 09-28-2008, 07:02 PM
new wvo heater
do you have loads of glycerol laying around? I found a way to use mine up. I made a oil heater out of some old furnace parts and a well pressure tank. I put the glycerol in the tank, pressurize the tank to about 25 psi, run the glycerol through copper lines to a furnace burner/blower motor to heat my wvo in a 100 gallon drum prior to bio processing. the stuff burns clean and hot, just getting it lit requires a small soldering torch due to the high flash point of the glycerol. this works great for dewatering your wvo..
Old 10-02-2008, 08:37 AM
sounds interesting. Do you have some pics of this setup? I would sure like to burn my glycerol to heat my oil vs using the electricty and a water heater element!
Old 10-02-2008, 02:10 PM
you realy need to read this link..Acrolein - Wikipedia, the free encyclopedia
from what I've been told from a very informed source burning glycerol at less than 1200* forms Acrolein gas which is basicly mustard gas and is very poisoness. I read through this link and decided that the electric heater realy didn't cost me that much
Old 10-09-2008, 08:17 AM
Whoa, good info! Good thing you caught that quickly haha
