adding diesel fuel treatments to veggie oil - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 09-26-2008, 09:12 AM
i run straight veggie with a mix of diesel 1/10. does anyone know if it would be alright to mix stanadyne performance with the veggie oil?
also what kind of fuel treatment do you guys perfer and why?
Old 09-26-2008, 10:19 PM
Don't Do it!! I have run sme tests using a variation of Diesel, WVO, SVO, and good ol #2diesel. adding diesel additive greatly destabilized the oil promoting much quicker polymerization than even just WVO alone. However diesel added to the oil at a rte of 10:1 appeared to all but eliminate the tendency for polymerization. Bottom line, just keep doin what your doin.
Old 09-27-2008, 11:16 AM
Can you post a link to the pics I once saw of your wife's muffin tins filled with all of the fuels and additives you experimented with? Those were great pictures. I was especially interested to learn that a little DK caused greatly accelerated polymerization.
Old 09-27-2008, 04:35 PM
911 additive
I dump in a bottle of 911 into my storage tank....even tho i filter and heat and run my oil through a centrifuge I pour in a bottle of 911 to guard against any water that might sweat into the tank.....this is the only additve i use. 911 is used to stop diesel from gelling and for water in fuel....i figure if it works for diesel it should work fine for WVO
Old 10-08-2008, 01:40 PM
So your saying polymerization will be increased by adding additives? What are you adding to make up the 10% energy loss?
