Kinda confused, I have been running SVO.. - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 12 Old 12-28-2013, 06:20 PM Thread Starter
trone12's Avatar
Cool Kinda confused, I have been running SVO..
Hello everybody, I am kinda confused to the fact everywhere I read says people convert there systems over to 2 tanks for SVO/WVO. I live in Northern Michigan where it does get cold. But during the summer months I run SVO that has been run thru a processor, it is extremely clean. Here is my dilemma, for the months when the outside temp gets above 50 degrees, I pour it directly into my tank. I do not premix or dilute it with anything. I run 100% right outta my tank. I have not yet had any problems. (Knock on wood). Somebody enlighten me why I am so different. Oh ya I have a 2002 7.3 f250.
trone12 is offline
post #2 of 12 Old 12-29-2013, 06:06 AM
The only reason you have not reached a catastrophic failure thus far is because you have not burned enough yet.
However, it is coming. With your method, look forward to valvetrain, injector, and and a host of other PITA issues. Including, but not limited to
Pump failure
Plugged in tank filter
poly in stock steel lines
degraded FPR
plugged stock check valves
delaminated fuel filters
coking on injector nozzle/tip
water damage in injector barrel
coking in piston cup
ring coking
leaking valve seats
broken push rods
premature main/cam bearing failures from engine oil cotamination
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #3 of 12 Old 12-29-2013, 08:37 AM
Snake's Avatar
Quoted: 46 Post(s)
Pump failure
degraded FPR
ring coking
leaking valve seats
broken push rods
Couldn't have said it better.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #4 of 12 Old 12-29-2013, 04:54 PM
simone0414's Avatar
Veggin is right. You WILL eventually end up with problems. Many have ruined engines doing exactly what you are doing.
You have two choices. Convert the fuel(biodiesel) then you can run it with no conversion or install a quality 2 tank conversion & burn SVO. If you live in a cold climate I suggest SVO cause you can burn that 100% all year round. Minus startup & shutdown time.
A quality DIY conversion will cost approx $2000 -$2500 & a kit will run you as much as $4000. The problems Veggin has listed could easily cost you 5 grand perhaps more worst case.
What are you using for a processor? Are you dewatering as well as filtering??
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #5 of 12 Old 12-29-2013, 05:28 PM Thread Starter
trone12's Avatar
So basically in a nut shell because I am running the oil at not the right temp, I am looking at a catasraphic failure?
As for the processer, the water does get evaporated off by air and heat and a aggitator, also I don't know what it is called exactly but it gets washed with lye and alcohol also.
I guess any help would be greatly appreciated. I do not want to hurt my motor. The truck does run pretty good and likes the clean veggie oil. Oil changes look great, no smoking out the exhaust .
trone12 is offline
post #6 of 12 Old 12-30-2013, 02:00 AM
Snake's Avatar
Quoted: 46 Post(s)
Basically, yes. Starting your engine on oil that's at ambient temps will make the oil smoke, leave sooty deposits inside your cylinders (coking), and then a valve or piston rings stop fully seating. If it's your rings, you'll eventually have veggie oil blow-by and SVO in your crankcase with your engine oil. SVO + engine oil + heat and pressure = Playdoh.
t just so happens I have a two-tank conversion system for sale (see sig).
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #7 of 12 Old 12-30-2013, 03:52 AM
HOLD THE PHONE!
What I think you are running is Biodiesel.
Alcohol combined with lye (NaOH or KOH) is methoxide. Methoxide combined with heated oil creates glycerol. When the glycerol is removed, what remains is biodiesel.
You mentioned "dried", thus you lead me to believe you are describing water wash.
Find out the specifics from wherever you get this "fuel". If the person you get it from says it is in fact B100, I can hook you up with youtube videos of a couple simple tests to see how good of fuel you have.
99 F350 7.3
B100 by Biopro 190
post #8 of 12 Old 12-30-2013, 04:03 AM
Keep in mind, qualiy B100 can be run as low as 32'F without issue in a PSD. By adding 20% D2, you can go as low as 20'F in most instances.
Quality B100 is perfectly harmless to be run in a 2002 PSD without modification when temps permit, in fact they LOVE it! It is a clean burning, low odor alternative fuel. In fact I made the switch from WVO to B100 over two years ago, and will NEVER run a drop of WVO again. From my experience, B100 is a MUCH better fuel. Burns clean. Runs strong and easy to handle. I feel it is MUCH safer to the engine especially in very cold temps. I run it year round. I will be driving to work today on B100 in my VW on B100 (fully converted) as the current air temp is -22F, and the high today will not be above zero. That could not be safely done on VO, at least I never could, and believe me when I say that I tried. The advantage to B100 is that it needs only to be heated to a temp above 32'F, compared to WVO at 160'F. Heating b100 to flowing temps is a snap. VO, not so much.
Check with wherever you are sourcing your fuel from. We can get you running it safely.
99 F350 7.3
B100 by Biopro 190
post #9 of 12 Old 12-30-2013, 04:07 AM Thread Starter
trone12's Avatar
I will get back with you guys tonight. I will see my fuel source gentleman today. Thanks for all the help so far.
trone12 is offline
post #10 of 12 Old 12-30-2013, 10:18 AM Thread Starter
trone12's Avatar
All that worry for nothing. At least I am a little smarter now on what goes thru my motor and the differences in fuel types. I do run B100 biodiesel thru my truck. I feel a lot smarter now with the help of people's knowledge on these forums. Thanks everybody
trone12 is offline
