Dual Tank - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 09-15-2008, 03:09 PM
Dual Tank
Has anybody used the dual tank set up on obs to run wvo. I was thinking about putting a bronco rear tank about 33 gallon on my truck running a coolant line in the tank and hooking the lines up the factory fuel system. Im worried about if the fuel switch block can hold up to the heated oil running threw it.
Old 09-15-2008, 06:01 PM
I have for 2 1/2 years and 25K WVO miles with the Plant Drive kit. Using the stock filter for WVO and diesel is asking for trouble. Each tank really needs it's own filter and the vegoil filter needs to be heated. This is just scratching the surface.
Old 09-16-2008, 07:04 AM
my buddy has been running svo into his superduty stock for couple thousand miles with just mixing the diesel and oil the tank. He did add a aftermarket fuel filter to his system though not heated. What if I had a heated aftermarket before the fuel switch, that should make the system work perfect wouldn't it.
