Best way to install ball valves on a 55 gal drum - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 17 Old 09-09-2008, 06:55 AM Thread Starter
So I just got the vegistroke install done, and now going to purchase a filter housing and I already have a few 55 gallon drums. How do you guys go about welding or soldering a ball valve on the bottom of the drum to drain?
The ball valves are thick and the drums are thin so is there a special ball valve you guys use to weld on or what?
Any ideas and pictures would be helpful.
I noticed this awhile ago but dont want to pay that much unless I have to.
55 gallon Drum w/Fittings at F2F Filtration Units
Thanks.
2003 7.3L
DP Tuner
9.5" lift
37" Toyos
JW Trans
Vegistrokin
optx002 is offline
post #2 of 17 Old 09-09-2008, 10:33 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Weld or braze the proper size nipple into the drum and then screw the ball valve onto the nipple. You don't weld the ball valve directly to the drum.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 17 Old 09-10-2008, 03:44 AM
I cheated. I took a closed top 55 gal barrel, flipped it upside down, cut the bottom off and screwed a 3/4 in. nipple into the small bung hole. Make sure the large bung is tight and use a thread sealant on both holes. So far this is working good.
Taz
2008 F-350 Lariat 4x4 DRW LB
WildTaz is offline
post #4 of 17 Old 09-10-2008, 09:40 AM
+1. This is the way to do it. Any welder can do this without much trouble.
'06 F-350 SRW 6.0 PSD
Albin is offline
post #5 of 17 Old 09-10-2008, 11:14 AM
PGreenSVT's Avatar
That is the easy way to do it but if you have open top drums which I assumed since he asked about welding I told him how to weld it up. No welding is required with closed top drums.
RIP Mitch
the Org crew
post #6 of 17 Old 09-10-2008, 07:10 PM
This is the setup I used...a weathertight electrical fitting from Home Depot. I replaced the rubber gasket with a Viton gasket, but otherwise, all the fittings are from HD, save for the locking ball valve that is from McMaster Carr.
Takes a little work, but does avoid the welding.
2006 F-250 PSD CC 4x4 FX4
2008 F-250 PSD CC 4x4 FX4 - Sold!
2005 F-250 PSD CC 4X4 FX4 - Traded!
Vegistroke V3 - 115,000 miles and counting!
2000 Camaro SS - Sold!
Marv is offline
post #7 of 17 Old 09-11-2008, 04:47 AM
PGreenSVT's Avatar
Now that's a clever solution I haven't seen before. Thanks for posting that up.
RIP Mitch
the Org crew
post #8 of 17 Old 09-11-2008, 04:55 AM
Not bad. Where did you get the Viton gasket?
Thanks,
Al
Albin is offline
post #9 of 17 Old 09-11-2008, 05:29 AM Thread Starter
Thanks,
Al
Ditto,
Where did you get the gasket from?
2003 7.3L
DP Tuner
9.5" lift
37" Toyos
JW Trans
Vegistrokin
optx002 is offline
post #10 of 17 Old 09-11-2008, 08:07 PM
No problem...hope it helps everyone out!
Marv is offline
