| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
Used Trans Fluid
I have been running a 50/50 mix of diesel and used trans fluid for about 8k miles with no trouble. I filter it through 2 fuel filters for a 2003 f-150 then put it in the tank. I would like to know if anyone else is doing this, what yall are filtering with, and the results.
thanks |
tranny fluid is highly detergent and will eat the seals out of your injectors not to mention not lubricate them properly so you will have metal wear as well.
+ diesels use the fuel to lubriace the uper cylinders and adding a detergent to your fuel cant be good on them either. thats just my 2 cents. good luck Last edited by rankroddin250; 08-18-2008 at 01:16 PM. |
everyone i have read about doing it in anything other than an IDI truck, has ruined their injectors
I run a 50/50 mix in my '02. Runs quieter, no loss of power and very little smoke.
How long have you been running that toptech?
my brother in law and i have been running it for 6 months now with no change in performance 50/50 mix i have and 08 and he has a 06 we filter it threw a 5 micron and then a 3 micron and then threw a inline tranny filter with a magnet in it
Just started a couple months ago. I filter it with a 2 micron NAPA (wix) fuel filter.
Thanks for the info guys. can yall tell me the part numbers on the filters yall are using. I dont know what micron my filters are. I just went with them cause the fittings on either end of the filter are easy to put hoses on and i just figured if good enough for one injector then should be good for another.
I met a guy a few weeks ago at a SoCaPS (southern california powerstrokes) meeting who was running a 90/10 mix of tranny fluid/diesel for quiet awhile with no problems. His excursion was modded and i don't remember if he had done an injector upgrade. He gets the tranny fluid for free and said it works great.
All I have to say is RED DYE! And ...oh yeah.....good luck.
