Vegistroke Installed! Questions now.... - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 55 Old 08-12-2008, 06:04 AM Thread Starter
mdub707's Avatar
Ok finished up our install on a buddies truck. Only a few minor issues. Apparently we didn't push the plug back on to the facotry fuel pump hard enough last night and the truck wouldn't start! Luckily that was the only electrical connection we did yesterday so we knew right where to look, got everything up and running. We started the truck and let it warm up in the yard. The green light on the switch never came on though. We drove the truck for about a 4-5 mile drive, and about half way through the oil temp was even up to normal operating temp. Green light never came on. We pull back in the driveway and roll down the windows. It was definitely switched over to WVO and burning it. Shut the key off, and the motor continued to run, and purged the lines out. We restarted truck and put it in manual mode, the green light came right on. For some reason in auto mode, the green light does not come on!? Anyone have any suggestions trouble shooting this? It is functioning, just the light wont come on, so we dont know when it's actually switching over.
After laying on the ground in a puddle of water in torrential downpour last night, getting covered in hot fuel, mud and having my hands burnt and scraped to look like hamburger, I just didnt' feel like messing with this light, since the system was obviously working. I still smell like diesel, and I had nightmares about the bolts on the back of the motor!
DamnKids Motorsports
2006 F-250 6.0 4x4
Innovative Diesel Tuning 466/772 7/19/08
VEGISTROKED
mdub707 is offline
post #2 of 55 Old 08-12-2008, 06:10 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
DFA had a batch of bad pressure switches and this could very well be what your issue is.
I have been reading on the DFA forum and there are a couple of peeps on there with this same situation.
I would contact Jason and see if he agrees and he will put you on the list for a new one.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #3 of 55 Old 08-12-2008, 06:13 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Most people have nigh mares about things like Freddy Kruger or Jason....
post #4 of 55 Old 08-12-2008, 06:19 AM Thread Starter
mdub707's Avatar
The bolts seem more intimidating than either of those guys.... haha.
We followed the instructions put up by Marv, and used the same tool setups he did, which worked awesome, so big shout out to him. I cant wait to get mine ordered and hopefully I can convince someone else to do those back motor bolts this time, I seemed to be the only willing participant to dive under the truck in the water pool haha.
2006 F-250 6.0 4x4
VEGISTROKED
mdub707 is offline
post #5 of 55 Old 08-12-2008, 06:37 AM
I think as usual, Clay is dead on with his diagnosis. The first time I tried mine, the light wouldn't light up and the system wouldn't switch over. Light worked great in manual mode though.
After talking with Jason and Clay, they traced it down to a pressure issue. In my case, the regulator was set too low. It should be all the way out and then two complete turns in and then snug up the lock nut. After that, she switched over just fine.
Hope you get it sorted out!
Thanks!
2006 F-250 PSD CC 4x4 FX4
2008 F-250 PSD CC 4x4 FX4 - Sold!
2005 F-250 PSD CC 4X4 FX4 - Traded!
Vegistroke V3 - 115,000 miles and counting!
2000 Camaro SS - Sold!
Marv is offline
post #6 of 55 Old 08-12-2008, 06:39 AM
Mdub, I have to agree with you...haha. That was the part of the install that I dreaded the absolute most. Was't too bad after it was done, but I don't think I'd want to do that everyday...whew.
Glad the instructions helped by the way!! Good to hear of another successful install!!
Thanks!
Marv is offline
post #7 of 55 Old 08-12-2008, 06:41 AM Thread Starter
mdub707's Avatar
Thanks!
Thank you for posting them! We used your instructions more than the DFA ones haha. The allen wrench being cut down and the 17mm wrench getting cut in half saved us a ton of time and headache, and we have you to thank for that!
Our system switched over to veggie, it was running WVO for sure, but the light wasn't working.
2006 F-250 6.0 4x4
VEGISTROKED
mdub707 is offline
post #8 of 55 Old 08-12-2008, 07:10 AM
Sounds like it worked out ok then - glad to hear it. The cut down wrench idea was born out of many minutes of frustration after trying to get a full size wrench in there.
Heck, I had a hard enough time getting my hands in there, much less a bunch of tools...haha.
I either need smaller hands or more elbows and wrists if I'm gonna keep working on these cars and trucks!
Marv is offline
post #9 of 55 Old 08-12-2008, 10:45 AM
I overnighted my bad sender back to dfa for analysis.
to check that suspect pressure sender w/meter;
key off, and sender unplugged:
Red - Black = normally open
Blue - Black = normally closed
If you see anything different then it's bad.
2005 Excursion 6.0l
wilson & Co is offline
post #10 of 55 Old 08-12-2008, 10:50 AM
Good info there Wilson, thanks! I checked the temp sensor when I was troubleshooting (as you suggested), but was curious if there was a way to check the pressure sender.
I'll have to file that info for future reference.
Thanks!
Marv is offline
