Cavitation on cold start - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 07-14-2008, 10:47 AM
Ever since the vegistroke install in my 02 7.3 the engine cavitates when I first start it up. A very light tap to the gas pedal smooths it out to its regular idle. Only does it on a cold start when I'm using diesel. Anyone care to guess whats happening and what should I be checking?
Old 07-14-2008, 11:32 AM
When you say "Cavitation" do you mean it's not idling smooth for a few seconds??? If so your engine oil is too full or your not "purging" all of the WVO out of the injectors prior to shutting the motor down.
Old 07-14-2008, 12:31 PM
Yes, the engine does rough surging until I tap the pedal. As soon as I tap the pedal the idle is smooth as a babies azz. Only the first start up in the morning.
Engine oil is full but not overfilled. Truck runs for 50 seconds on shut down for purging. According to Vegistroke I should expect a less than 1 minute purge. I would hope that is not the issue. I suppose if nothing else comes up to "check" I'll see about dialing up the purge time a little bit and see if that eliminates the problem.
Old 07-14-2008, 01:10 PM
I can always tell when I didn't get all of the WVO out of the injectors, my truck will do exactly what you are saying......
Old 07-14-2008, 01:30 PM
How long do the rest of you Vegistrokers purge for?
