Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Bio-Diesel/Alternative Fuels and Supplements
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 11-01-2006, 12:01 AM
freemand1 freemand1 is offline
Cold weather starting ?
Anyone know anything about cold weather starting, and or, additives to help my bio-diesel powered truck start on cold mornings? brand names and where to get it would help a lot.
Old 11-01-2006, 12:03 AM
Logan Logan is offline
The Fat Mod
I have used diesel kleen in the white bottle when it gets cold. And plug your truck up. Thats the best thing I think.
Old 11-01-2006, 12:05 AM
The Fat Mod
Hey Freemand, could you please put your truck info in your sig and we will be able to help you better.
Old 11-01-2006, 12:40 PM
Clay Henry Clay Henry is online now
Sooner Powerstroker Mod
What blend of Bio-D are you using? The best reccomendation for cold climates is to use more diesel and less bio. If your using B100 (100% bio) then you should cut it back to B10 or B20 and it should be fine.
Old 11-04-2006, 10:45 AM
Thanks, I dropped down to about B50 and things are running fine, starting fine.
