Vegiestroke Installed on 7.3L - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 07-13-2008, 06:37 PM
I just wanted to let everyone know I just completed the install. Best of all the truck started and switched over to vegie after about 15 minutes of ideling. I must say I was stressed about this install because I have never tried something like this before...but is was not bad at all. It was easy. Clay and Marv you are the reason I went with the vegiestroke. Thanks for all of your help. For those of you on the fence the instructions were straight forward and the kit was complete. I would recomend the Vegiestroke and DFA to anyone.
Old 07-13-2008, 06:45 PM
hey, im planning on doing some veggoestroke here soon, but i was wondering about the o rings. ive heard that you have to change your oring on the fuel system, im not sure on just the injectors of the whole thing, anyone have any info??
Old 07-13-2008, 07:49 PM
Change what O rings? are you talking about the injector O rings? Biodiesel may over time have some effect on on the stock diesel system, but WVO doesnt harm anything.
Old 07-13-2008, 07:56 PM
I don't know nuttin....
Glad to here it...get that grin off your face...oh wait, you cant!
Old 07-13-2008, 08:00 PM
Congrats on the install, it's by far the best modification that you can do to your truck. Does it have a manual override so when your truck is idling for long periods of time you can switch back to diesel??? Whenever I let my truck idle for more than 10 minutes or so I always idle on diesel.
Old 07-13-2008, 08:06 PM
<<---"Shadow"---
Just for MY information, why do you idle on diesel if youre idling for extended periods of time? Thanks.
Old 07-13-2008, 08:14 PM
Due to the animal fats and PHO, wet stacking is a problem while idling on WVO.
Old 07-13-2008, 10:06 PM
I do the same thing. Wet stacking is not good even with diesel and I want to avoid it even more with WVO. Whether or not the consequences of wet stacking are worse with WVO than diesel, I don't know, but it seems to me that they would be.
Old 07-14-2008, 01:54 AM
Thumbs up
When you convert to the Vegiestroke you have to add two check valves to the factory fuel system. DFA (Vegiestroke) tells you to change the degerdaded o rings before putting the fuel lines back on. They were degerdaded (from diesel) but the best thing was the new ones come in your Vegiestroke kit.
Old 07-14-2008, 01:56 AM
It does...How long is "long periods of time"?
