vegestroke install question - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 10 Old 07-13-2008, 06:46 AM Thread Starter
just finishing up my install and i need to know where the 2wires {black and grey and black with eye ring} inside the cab on the main harness i believe they are for the heat mat for the filter on the outside. but i could not find any thing in the instructions for where to hook them up inside? hope this is not confusing
jason
jasngen is offline
post #2 of 10 Old 07-13-2008, 07:11 AM
I just went out and checked my install... I attached a gray wire with a black stripe and eye ring to ground. The black wire is certainly ground also.
Looking at the instructions, I don't know why I attached it to ground, but I would remember if I had to figure it out so it must be buried in there somehow.
sbaker is offline
post #3 of 10 Old 07-13-2008, 08:20 AM Thread Starter
thanks i will try it , i cannot get mine to start! grrrrrr
jasngen is offline
post #4 of 10 Old 07-13-2008, 08:50 AM
Did you try the little test steps that are outlined in section #5, item #13 in the install manual?
sbaker is offline
post #5 of 10 Old 07-13-2008, 08:55 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 31 Post(s)
I talked to him, it turned out to be a blown fuse to his fuel pump...he got it fired up.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #6 of 10 Old 07-13-2008, 09:20 AM
Congratulations Jason, welcome to a whole new world .
sbaker is offline
post #7 of 10 Old 07-13-2008, 09:23 AM
<<---"Shadow"---
sea71's Avatar
Congrats for sure!! I am jealous. lol!! I am leaving here in a few minutes to go talk with my FIRST grease supplier about pick up days!! Woo HOO!! Then I got to get started on securing the Vegistroke set up. EXCITING it is indeed!
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
post #8 of 10 Old 07-13-2008, 11:31 AM Thread Starter
thanks everyone , i just gave it a test drive and she went to veggie in about 4 miles,
3rd best feeling in the world. very impressed with this kit. you can really tell while doing the install the amount of r&d that went in to it. WORTH EVERY PENNY! thanks again clay your posts had a lot to do with me getting my kit and even more to do with me building my home filtration setup {i basically copied yours} so any ways i will report back as time goes by on how my vegistroke setup is going.
btw my hands look like they were the rope in a pitbull tug o war after the 2 banjo bolts in the back of the motor.
jasngen is offline
post #9 of 10 Old 07-13-2008, 04:05 PM
HorseMover's Avatar
Quoted: 29 Post(s)
Wipe that grin off your face - Opps I forgot you can't. Congrats on the successful install!
2012 F-350 CC Lariat Dually
HorseMover is offline
post #10 of 10 Old 07-13-2008, 08:00 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 31 Post(s)
Glad i could be of assitance... call me if you need anything at all!
