| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
$188 tank of fuel
Ok guys these fuel prices are getting ridiculous. I have a 2003 F350 stock crew cab dually, with a 7.3L and around 175k miles on it. As far as i know it has never been run on any alternative fuels. My dad makes Bio-Diesel and has been running it in every diesel hes had, all chevys though. I would be able to get it from him rather than at the pump. I read diesel world and diesel power mags all the time and they say that i could have some problems if I just start running B100, being its an older vehicle with some milage on it. That the B100 will start loosening deposits from all the years of build up in the tank and fuel lines and eveywhere else. And that it could get into my injectors and other things. I really cant afford for things to start breaking if I start using B100. I would much rather fill my tank for free rather than $188 at the pump. So I guess my question is what will i have to worry about if i start using straight B100?
If your father is making it, and he will give it to you pretty much for what it costs him to make it, run the piss out of it. My current vehicle is a 00 7.3 with 226K on it. Bought it with 217K and 9k have been 100% alternative B100 and WVO in a vegistroke. Like clockwork just the same as my 1995 7.3 that I had the fuel filter will plug within the first 500-1000 miles so just carry a spare with you. If you have changed the filter before its pretty easy and can be done roadside in 5 mins. once you plug one filter from all the crap that has biult up in your tank over the years and you wont have a problem after that.
First Filter after 2000-4000 miles. Next filter at 8k miles and then 12k. After that you should be able to stick with normal filter changes.
But the point is the filters will plug until you flush your system of all the crud that has built up over the years. After that you will have the cleanest tank ever!!! The filter will stop everything so I wouldnt worry about plugging injectors. Plus the BD will probably dissolve any junk in your injectors if you or previous owner have never run and cleaners through it. Another good thing to do when you change a plugged filter, is open the fuel drain and run a good bit of fuel out it say a 1/4 gal. Key on, but engine not running, will help to flush anything out that has made it to the filter housing but prevent it from plugging your next filter. |
ok got the filter part but what about gaskets and o-rings and fuel lines and things of that sort. im pretty sure i have metal fuel lines but not positive on everything else.
