Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Bio-Diesel/Alternative Fuels and Supplements
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 07-02-2008, 06:55 AM
tubular031 tubular031 is offline
Blue Harbor Freight pumps – read this if you gotem
I posted this on another forum under a debate on what pump to use. Most suggest the blue Harbor Fright pumps and many warn about them blowing or catching on fire…
Here is a little Vid I made that shows the voltage and the blown cap.
I thought I would share this with you guys. One of my blue harbor freight pumps went up in smoke last weekend. We use this one for water only to water the garden. The run cap popped and puked its guts out inside the plastic power box on top and made some smoke. Now that the run cap was out of the loop the windings on the inside are introduced to the straight line voltage and they started to burn/ melt. Good thing I was standing there when it popped and pulled the plug before the windings could melt and short the motor.
So here is WHY they blow. My dad’s house line voltage is 130 usually. We have even seen up to 136 at times. Well the run cap is only rated at 240 v. Now if you have 120 line volts then the voltage across the cap is 240 which is JUST hardly with in the caps limit.
I don’t know exactly why the windings and the cap measure double, but they do. I watched my dad measure them with the meter. He was explaining it to me but I can not remember right now as to why. My dad use to design motors and systems using motors (and also build electric motors) so he is some kind of genius at this stuff I guess.
Well my dad’s house is always 130+ volts and that puts the cap at 260 volts. Most caps can handle 5 to 10% over and be ok for a little time but not forever. If the cap pops and the windings melt, you will see lots of smoke (varnish on the windings melting along with the bamboo spacers in the middle of the windings) and you could see flames. Mostly smoke and stink.
So the fix? A cap rated at 370 or 480 VAC. Granger has them for 8.96 or allied has similar for 6 bucks. The cap that comes with the motor is a 16 uf (micro faried) 240vac. I bought a few 15 uf 370 volt caps and will be replacing them on all my pumps (2 Biod Pumps and 3 water pumps) Remember make sure that you get AC rated caps NOT DC. I did not express this the first time around (I knew it and assumed that everyone else would know...) but thanks to rydogg on another forum for pointing that out to everyone.
O the down side is that they need to be remote mounted since they will not fit in the box on the top of the motor. Ill try to get some pics soon for you guys.
I installed the grainger one last night and all was good. Waiting on the allied ones to show up and see if they are ok.
Motors > Motor Supplies > Capacitors > Run Capacitor,15 MFD,370 VAC : Grainger Industrial Supply
Cornell-Dubilier - 37FD3715-F - Allied Electronics
Here is the popped cap
Old 07-02-2008, 07:09 AM
hheynow hheynow is offline
Seρor Aceite de Soja
MADE IN CHINA
Old 07-02-2008, 07:17 AM
Normally I would agree with you BUT my wonderful GE start cap in my AC blew about 2 weeks ago. After pulling it apart and paying some monkey $175 to fix my AC (it was 99 that day) turned out to be a GE cap MADE IN CHINA! at freakin $16 part cost me $175 to fix because I did not know any better. So I started searching... look around on all the HVAC places, these GE caps made in china were poping like mad too. Can we find anything these days not made in china?!?!?! Man I hate that cheap crap! but what can we do
Cap pic posted
Old 07-02-2008, 07:36 AM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
Northern Tool has a blue 1" water pump that looks just liek the HF one. It is rated at twice the delivery amount and cost 10 bucks more.
I ordered one 2 days ago to replace/backup my 2 year old pump.
Old 07-02-2008, 07:41 AM
I have seen the northern tool ones and they sure look like the same thing in the pictures. A buddy of mine has them on his processor and without popping them open, they look just like my HF ones. One of these days ill tare his apart and see what the insides look like.
For many that only have 110 to 120 volts on thie line you probably will not have to worry, but if there is a spike in the line volts you can and probably will pop a cap. If you read around on thses pumps lots of people talk about them frying. Thought I would share an experience of one frying. Ill take pics tonight
Old 07-02-2008, 08:24 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
If it is not made in China, it is made in Indonesia, Taiwan, or some country you can not pronounce or even think of spelling. Even the citizens of the country can't spell the name correctly.
Old 07-02-2008, 09:30 AM
Originally Posted by tubular031 View Post
So the fix? A cap rated at 370 or 480 v. Granger has them for 8.96 or allied has similar for 6 bucks. The cap that comes with the motor is a 16 uf (micro faried) 240v. I bought a few 15 uf 370 volt caps and will be replacing them on all my pumps (2 Biod Pumps and 3 water pumps)
Originally Posted by hheynow View Post
MADE IN CHINA
Good news, I got my Caps in from allied today and they are not made in china! But they are not US made either.... they are hecho en mexico. o well...
Old 07-02-2008, 09:55 AM
Motown Fire Motown Fire is offline
I just got a 1" pump that is IDENTICAL to the northern tool and harbor freight pump. Found it new on ebay for $29 + $10 for shipping. Works great for pumping hot oil through my house water filter.
Old 07-02-2008, 10:27 AM
dezl dezl is offline
myself and a buddy use the 1" HF pump for our biodiesel processor and weve killed 2 of them in a month. The first lasted a few weeks then just died, no pressure at all. The second one we wired up primed it and nothing at all....those pumps are garbage. Not to mention we cant find any of them to replace our broken crap. Kinda Pissed!
