Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Bio-Diesel/Alternative Fuels and Supplements
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
  #151 (permalink)
Old 08-06-2008, 03:57 PM
BryanH BryanH is offline
LSP Officer
Tag............................
  #152 (permalink)
Old 08-14-2008, 09:22 PM
powerstrokes only powerstrokes only is offline
New generator
Just finished a new generator built out of a coke canister that is used in resturants and convienience stores, and so far so good! I achieved a true 21.4 mpg with it in all city driving with lots of stop and go. This is on a '94 IDI factory turbo, 4:10 rear end, and it has over 300,000 miles. The engine is running smoother and the power is up a whole lot, I have not pulled with it yet but I expect good things!
  #153 (permalink)
Old 08-14-2008, 09:42 PM
somebodyelse5 somebodyelse5 is offline
im real interested, but i feel like i missed a good amount of info lol.
how well would this work on my 02? and it looks like there are some very knowledgeable guys on here.
How much are these kits costing? (a high quality kit, that you guys have tried)
  #154 (permalink)
Old 08-15-2008, 03:51 AM
A8050266 A8050266 is offline
how about some pics???
  #155 (permalink)
Old 08-15-2008, 07:00 AM
hpf350 hpf350 is offline
this link can set anyone up who is jumping on this thread late
http://www.water4gas.com/
i haven't started yet but i've done lots of research on the subject.
some guys have posted photos.
more would be better!
hope to see some more images soon.
i know there are lots of photos on google images but few are of generators installed.
  #156 (permalink)
Old 08-15-2008, 07:21 AM
I'll see what I can do.
  #157 (permalink)
Old 08-15-2008, 04:23 PM
SuperDuty73 SuperDuty73 is offline
Do you know what the output in Liters a minute it makes? good job!
  #158 (permalink)
Old 08-20-2008, 05:26 PM
thelittle289 thelittle289 is offline
I have made a few home made generators, know they made hydrogen but never hooked them up to any motors. Bought a system from hydro fuel solutions. I like the design of the generator the best after taking the generator itself appart and seen the design, and I have seen a bunch. I really like the fact that this system collects the gas in a seperate tank and you can defentetly see the hydrogen bubbles in the lines to the tank. I didn't want to hook it up to my 99 till I knew it wouldn't blow up. I have an 84 with a 6.9 I run on WVO but couldn't find room under the hood to mount the big unit under the hood properly. So i hooked it up to a single cylinder diesel and didn't get any differance, as a matter of fact out of 5 tests one came in just under the test with no hydrogen, thay were all within minutes of each other. What am I doing wrong?
  #159 (permalink)
Old 08-20-2008, 11:32 PM
kollerbill kollerbill is offline
How did you hook it up to the intake? After the air filter but before the turbo is ideal. Also what is you solution mixture? Use a good electrolite, potassium Etc. Don't use tap water, baking soda, or lye. Not pure HHO and can cause corrosion to generator plates. What is your HHO output? Diesels really can take a lot of HHO (EX: 6.0 can use like 3-5 liters per min)
I have been researching this for about 2 months, I don't know it all but have a good idea what's going on. I have purchased a complete system with 2 generators, a water tank, and all the electronics to make this thing work at max efficiency. It's not in yet. My biggest thing is where am I going to put it. Have you seen under the hood of an 08 yet! I will be sending picts and maybe spend a little money on a dyno. I'm thinking of pulling the fan and shroud and building a new shroud with brackets to hold the generators between the rad and the engine.
  #160 (permalink)
Old 08-21-2008, 02:23 PM
Dont worry its not going to blow up... I am a dealer for hydro fuel solutions and there is no way for them to blow up. the water will stop any backfire... and I have yet to see a diesel backfire so your fine.
Did you buy a double unit? you might not get alot better mileage if your truck has spilt shot injectors. due to the HHO is burnt up in the first procces of injection. Good Luck!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
