Tote stacking?? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 6 Old 07-16-2013, 06:59 AM Thread Starter
vandy's Avatar
Tote stacking??
im in the early stages of wvo collection and filtering. my filtering setup is almost done. my issue is i am getting a lot of oil coming in. I just got a lead on 80 Gal that i can go pick up today. i have one empty 275 gal tote that i was planning on using for clean oil. my question is, could i stack them. put the clean oil on the top, old oil on the bottom. eventually the clean oil would be heavier than the dirty oil bin. im worried out that weight being on top and if it could hold the weight?
vandy is offline
post #2 of 6 Old 07-16-2013, 08:15 AM
timmyboy76's Avatar
i wouldnt stack with nothing bracing. What about building a metal rack TO stack them, then?
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 6 Old 07-16-2013, 10:48 AM
Stack them up to three high and dont worry about it. Thats what they are made for. Most totes came across on a boat in a sea container. THREE high.
I stack full totes two high and have done so for years.
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #4 of 6 Old 07-17-2013, 10:44 AM
simone0414's Avatar
Depends on what you are stacking them on. That's alot of weight to hold up. Concrete floor Right one the ground for example that would concern me. I wouldn't feel comfortable stacking them 3 high no matter what but that's just me. 2 high
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #5 of 6 Old 07-21-2013, 08:29 AM
timmyboy76's Avatar
past a batch plant the other day (concrete mixing plant), and happened to see that, their stacking 2-high, and they looked full to me...
post #6 of 6 Old 07-26-2013, 01:43 AM
Cashflo's Avatar
All metal caged totes can be stacked atleast 2 high(granted this is if they have no damage). Some brands can be stacked 3 high but its usually only the 250 gallon ones.
I have a 250 on top of a 330 with a row of brick under the back side so the are slightly tilted forward.
I regularly climb up the side of 330 to get to the top of the 250. Ive tested the tipping ability of the 250 and anything over 50 gallons and it wont budge with my 245 lbs.
Handle every stressful situation like a dog.
If you can't eat it or play with it, just pee on it and walk away.
An Energy-Independent Future~~
Cashflo is offline
