Auxiliary tanks - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 8 Old 07-08-2013, 08:18 AM Thread Starter
vandy's Avatar
Auxiliary tanks
Here's my delima ...I'm in the process of a wvo system. Ill be taking a few long distance trips a year. I'm in okc and will be running to SoCal and the east coast. Should I
A) buy a tank off another member for cheap ($500 ish) thats a 50 gal and worry about extra storage or filling up on the trip when it happens
B) buy a 91 gal tank
If i go with a 91 gal tank should i go with one from BFT thats plumbed for heat. Or buy an RDS tank from northern tool and have a heating loop welded in ( would cost me a few cases of Coors Light)
I like the idea of the extra gallons, but not sure about the extra weight. And the price on the used tank is nice.
Any advice from the old vets would be nice. End of the day ill be using it (the truck) to haul a large 5th wheel.
vandy is offline
post #2 of 8 Old 07-08-2013, 07:19 PM
I don't recommend welding the heat exchanger proper. I use these with great success:
I use the bulkhead fittings and Viton gromets and make my own aluminum coils, however, the aluminum off the shelf will work fine for most applications.
Tank heating coil kit | Greasecar Vegetable Fuel Systems
The reason for not recommending welding the heat exchangers is that they can and will crack from the rapid expansion and cooling. Just that from personal experience drives me to use the above. Have never had one fail....
Good luck with whatever you choose....Always check craigslist. A reasonable priced used transfer tank and some quick couplings and valves, you can install a second tank with heat when needed.....Just my two cents.
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #3 of 8 Old 07-08-2013, 07:50 PM Thread Starter
vandy's Avatar
Thats kicka$$ness on a stick. Pretty much exactly what I'm looking for. If i don't go with the used bft tank I'll end up sumping the rds tank with that sitting in the bottom.
vandy is offline
post #4 of 8 Old 07-08-2013, 08:12 PM
That's how I roll. That set up in a one gallon sump with a louvered cover over the sump.
99 F350 7.3
B100 by Biopro 190
post #5 of 8 Old 07-11-2013, 02:01 AM
Vandy,
Veggin has you covered, but as an alt idea...
I do 3 or 4 long hauls a year, 200+ gal runs. I have a 100 gal regular veg tank and for the long hauls I went to a semi truck junkyard and picked up a 90 gallon D-shaped aluminum tank. Came with the sender and two pickups for $2/gal. They are harder to find than the circular saddle tanks, but I didn't want to screw with straps and keeping it from rolling around. All rectangular ones will be steel (according to the wrecker). Also, since its aluminum, I can pick it up and move it in and out the truck by myself. Goes in the truck before the trip and comes out after the trip. Pump from long haul tank to the reg veg tank at the end of the day of driving.
Only drawback is the damn thing sits in my way when I'm not using it.
veg-on,
2005 Excursion 6.0l Eddie Bauer, 175k
MtnOilRIG is offline
post #6 of 8 Old 07-11-2013, 04:25 AM
Another aux tank idea...
In the bottom of the sump, I welded a 3/4 NPT bung into it with a sst ball valve and 3/4 camlock. On long trips, gravity flow the second tank into the bottom of the sump via the camlock. No pumps required, and gravity is pretty reliable. You could even use a tote via a hose for almost unlimited range.
99 F350 7.3
B100 by Biopro 190
post #7 of 8 Old 07-11-2013, 06:44 AM Thread Starter
vandy's Avatar
Thanks guys. I love the ideas. I'm looking into all of them.
vandy is offline
post #8 of 8 Old 09-05-2013, 05:41 AM
Cashflo's Avatar
First, im just floored that grease car is offering a cooper version of the heating loop. They must be banking on the ignorant to use copper and have poly jack up their valves, so they can sell more.
I would also be leary of using their copper heating loop unless you replace that yellow metal with stainless.
Handle every stressful situation like a dog.
If you can't eat it or play with it, just pee on it and walk away.
An Energy-Independent Future~~
Cashflo is offline
