Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Bio-Diesel/Alternative Fuels and Supplements
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
  #21 (permalink)
Old 03-24-2009, 06:28 PM
nsrchofpwr nsrchofpwr is offline
lifetime member
subscribed
  #22 (permalink)
Old 03-25-2009, 06:37 AM
ridiculously_necessary ridiculously_necessary is offline
Originally Posted by orng1 View Post
Home Depot has those fittings, I found them in plastic for around $1 each. I needed 4 for the 2 filters I plumbed together.
i got a local goldenrod filter and fittings for that, but the filters are too expensive, so i got some cimtek filters and mount from jmesales.com. far less expensive. i have to go return the pluming i got from home depot, which was about $30 alone. with the cimtek the npt is smaller and i dont have reduce the pluming and all i need are the npt to barb fittings. about $5, ill probably go with pex if they have, i dont know that i trust pvc with that heat. i also hope i can find some cheap NAPA filters that will fit that mount too.
good to hear what you said, i was hoping it would work somewhat better than what im doing now...
  #23 (permalink)
Old 04-14-2009, 03:32 PM
Dave Nowlin Dave Nowlin is offline
I don't know where the information on the chart came from, but it is not accurate. I have sold filtration products for a living since 1986 and have viewed information from the medical field and other sources which will refute this information. A 99.99% HEPA filter is used where surgical procedures are done where the bone marrow becomes exposed to protect from post operative infection. This filter is 99.99% effective on a .3 micron particle. This efficiency is chosen to block bacterial contamination. The chart lists bacteria at 3 microns. Talk to the folks at CDC or an infection control doctor and see if they agree that 3 microns is the smallest size that bacteria can be found in.
I will also point out that a human being with 20/20 vision can see a 20 micron speck in good light if the speck is black and the background is white.
Dave Nowlin
