Greasecar tank filler cap leaking - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 2 Old 06-20-2013, 09:30 AM Thread Starter
simone0414's Avatar
Just installed a used GC 40 gallon tank. Today was the first day I filled it up all the way. Noticed after coming home from work some oil on the top of the tank & running down the side of it. 99% sure it is coming from the cap. Of course it is only leaking when I drive so it is hard to tell for sure but I believe it is leaking around the rubber gasket that seals the cap to the flange. It doesn't seem to seal as tightly as I think should. The gasket on the cap looks fine though. The tank has been sitting empty for over a year.
Never had a GC tank before so is this a common problem?? Is the cap serviceable or do I just need to get a new cap?? Tried logging on to the GC forum to post this there & for some reason it won't let me. I will call them if I have to.
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #2 of 2 Old 06-20-2013, 12:06 PM
Those fill caps suck.
I removed it and had an aluminum neck welded in.
Likely, the seal between the flange and the tank is leaking. Remove the screws and reseal, then reinstall.
While the fill cap is in hand, be sure to clean it. There is a vent in the cap. Its under the allen head screw. clean it up nice and reinstall.
A 1/4 cup of sodium hydroxide in a gallon of water will make it like new.
Be sure to use gloves, NaOh is potent, and dangerous.
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
