Waste Motor Oil for Fuel? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 40 Old 03-24-2008, 03:12 PM Thread Starter
Ok, I've been reading in here quite a bit, and only noticed 1 area mentioning this, so I'd like some input from you guys/gals.
I saw this on E-Bay, and got to thinking.....
SUMP OIL TO DIESEL PLANS = HOME MADE BIO FUEL FOR FREE! - eBay (item 270221410659 end time Mar-30-08 02:01:39 PDT)
I'm looking into the Bio-Fuel options, and this caught my eye. I have access to an AWFUL LOT of Motor oil....
Thanks for your thoughts....
RCFlyn is offline
post #2 of 40 Old 03-24-2008, 03:15 PM
scheidt27's Avatar
If its too good to be true it probably is. Im gonna go with a no, thats just me though.
2002 F250
Beans Diesel Performance Tunes
All Supporting Mods
scheidt27 is offline
post #3 of 40 Old 03-24-2008, 03:26 PM
d7rxr's Avatar
People I know have been adding their used oil to the fuel for years. Mostly they strain it through cheesecloth, and add about a gallon or so every tank, the truckers add the whole 5 gallons to their tank fulls.
d7rxr is offline
post #4 of 40 Old 03-24-2008, 03:28 PM
scheidt27's Avatar
I dont know, just the thought of used oil running through my injectors and everything else makes me cringe, even if it is filtered there is still crap in it
2002 F250
All Supporting Mods
post #5 of 40 Old 03-24-2008, 03:42 PM Thread Starter
From what I'm gathering from this E-Bay Auction, you're not really using the Used motor Oil in itself. It's being processed (Like Bio ???????????) to be converted to Diesel????
Without spending the $132 for the Info, I'm NOT Sure, but that's what I'm gathering....
RCFlyn is offline
post #6 of 40 Old 03-26-2008, 06:12 AM Thread Starter
No other opinions???
Anybody???
RCFlyn is offline
post #7 of 40 Old 03-26-2008, 06:45 AM
willholl79's Avatar
Sounds too good to be true, but who knows?
2005 F-350 CC LB 4x4 XL 6.0
SCT
4" Turbo back exhaust
03 turbo
Studs
Coolant Filter
Warren Stock+ injectors
1996 F-250 ECLB 4x4 XLT 7.3 Auto
1993 F350 CCLB 4x4 5spd 7.3 NA
willholl79 is offline
post #8 of 40 Old 03-26-2008, 06:59 AM
bfloyd4445's Avatar
Quoted: 3 Post(s)
waste oil is not bio fuel for one. and secound waste oil contains lots of toxic heavy metals which unless filtered out will be vaporized by the engine and put into the air for people to breath. Not a good thing
Britt
2007 F250 CC SB 4X4, SB, PSD, Lariet, stock
1975 Ford 2000 ROP Diesel tractor < ran without oil for 2/10 mile 7/12/2009> Stills runs as good as ever
"If you don't read the newspaper you are uninformed,
If you do read the newspaper you are misinformed."
-Mark Twain
bfloyd4445 is offline
post #9 of 40 Old 03-26-2008, 11:40 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
Some people are doing it, blending it with RUG and Kero. I wouldn't do it.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #10 of 40 Old 03-26-2008, 01:28 PM
d7rxr's Avatar
The truckers that I know that are using their used motor oil said they also use some kinda of a magnet in the screening process...I'm too chicken to do it myself.
d7rxr is offline
