Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Bio-Diesel/Alternative Fuels and Supplements
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
  #81 (permalink)
Old 08-10-2008, 01:52 PM
choctaw choctaw is offline
I'm #1 in the #2 Business
Originally Posted by Snake View Post
Clay -- thanks for taking the time to call me back yesterday, and again my apologies for jumping off the phone so quickly.
Yes, the Whirlpool WH I picked up from Lowe's only has 2 openings on top (hot and cold), 1 part way down the side (T&P), and one all the way down (drain).
Not gonna work.
So I returned that one to Lowe's and found out that WH's with the T&P on the side are for mobile homes. Why? I don't know. But that's all that they carried. So off to El Cheapo (Home Depot) and an extra $50 for a water heater that I can actually use.
Thanks to everyone for all the help. I couldn't go down this path without it!
--Snake
That is not true, just because the T&P is on the side does not make it "only" for a mobile home. The wattage of the elements is the difference.
Some manufactuers choose to put the T&P on the top and others on the side, there is no difference whatsoever in the tanks, jackets, or constuction of the W/H.
Sorry for the rant, I can't stand it when one of the "EXPERTS" at one of the big boxes make assinine statements.
  #82 (permalink)
Old 08-10-2008, 08:33 PM
Snake Snake is offline
I hear ya! I didn't ask why, I just knew that those heaters couldn't be used for dewatering WVO unless you only wanted to fill the tank 3/4 full. No point in paying for a 50 gallon water heater if you can only use 35-40 gallons of it. lol
--Snake
  #83 (permalink)
Old 08-11-2008, 11:46 AM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
when you gop to home depot, ask them if they have any scratched or dented heaters they will discount...it could save you a few bucks.
  #84 (permalink)
Old 08-11-2008, 05:05 PM
That was the first thing I did when I got there. I debated scratching or denting one myself and then asking for a discount but figured karma would come bite me in the heiney.
I have 95% of the fittings I need for the still and my platform is finally built. I have a few barrel strainers, a pump handle, and a 20' hose on order. After that, I just have to add power to the water heater and the pump and I hope to be up and running.
And of course the pump I bought from Northern Tools didn't come with the owner's manual. So I had to call and have one shipped.
--Snake
  #85 (permalink)
Old 08-11-2008, 07:56 PM
h2odrx h2odrx is offline
--Snake
I got mine of line and printed it out....
  #86 (permalink)
Old 08-11-2008, 08:57 PM
Was it for the Northern Industrial Pump model 109955? I've been searching the web and couldn't find a manual posted and Northern Tool said it wasn't available online to them (using their resources).
--Snake
  #87 (permalink)
Old 05-25-2009, 12:01 PM
tecelec1 tecelec1 is offline
how long does your filter last?
  #88 (permalink)
Old 05-25-2009, 12:59 PM
orng1 orng1 is offline
Depends how dirty the oil is you start off with. I've gone a few months on a filter and then there have been batches that I just changed it right after getting done. Some of the stuff starts growing some dot looking things.
  #89 (permalink)
Old 05-25-2009, 07:29 PM
the filter life is entirely dependant on your heat and setle process. If you do not heat and let settle long enough, you won't get 50 gal. out of a filter. If you do, you will get 350-400 gal. though a filter.
I get the latter.
  #90 (permalink)
Old 06-07-2009, 01:50 PM
tptfps tptfps is offline
Clay, First off, I already have a filtering system down to 5 micron that dumps into a 55 gallon barrel with a ball valve near the bottom for removal. what would be wrong with filtering then running thru the water heater to seperate the water? Also, why is it not recommended to use trans. fluid? I know guys at the ford dealer that are pumping used trans fluid straight out of the flush machine into their tanks. thanks
