- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
| Sponsored Links |
3 years down the road now using this setup and there has been no problem. I took a galvanized fitting off once and looked inside it and there was a layer of polymerized oil but all it could do is break loose and go to the filter which is ok. The heating elements in the water heater polymerized too and besides replacing those with SS elements, i don't know what else i could do about that. |
A tank will settle out in less time but i have to wait for it to cool. |
My setup
I use the Cold Up-Flow settling method for my fuel. I start by dumping the cubies into the blue barrel through a 5 micron sock filter. I stop pouring when I see anything but clear oil - no PHO goes into my filter barrel. Once full, I let that settle for a few days, then pump 8-9 gallons into the "funnel" on top of the Cold Up-Flow settling barrel (white steel). The oil in the funnel pushes the settled oil in the barrel out the top through the spigot. I open the valve so I have a small trickle going into my finished fuel barrel (white poly). I then mix my V/O and RUG (Regular Unleaded Gas) in the 20 gallon mixing barrel and hand pump it into the car or truck. It's a cheap and simple method for getting clean and dry fuel, and has been working very well for me! |
you have any good links for this Cold Up-Flow settling method?
| Sponsored Links |
