Purge time on 02 psd - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 8 Old 06-03-2013, 10:46 AM Thread Starter
Hello, just wanting to get some opinions on purge and run times (after switch back) on a DIY system using fittings from Wvo designs. I have the purge valve plummed in right after filter with all components configured in bed next to tank so purge line is roughly 12"'s long. Not sure how important but truck is crewcab long bed to give an idea of hose length. I had a different system on for last 3 yrs and just got my install completed this wknd so I'm brand new to it. Thanks in advance for your advice/suggestions! Matt
mmmkay is offline
post #2 of 8 Old 06-03-2013, 04:42 PM
simone0414's Avatar
Disconnect purge line from purge valve & switch back to D2 & open the purge valve. When you start you see D2 coming out then your good. Count how long that takes.Then run the truck for at least a minute before shutting down.
I purge for approx. 5 seconds then run the truck for approx. a minute before shutting down.
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #3 of 8 Old 06-03-2013, 08:20 PM
I would ask Leon. He designed the system.......
(actually, he just reverse-engineered the system. He ripped off the plans form DFA)
Sorry Leon lovers, couldn't resist!
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #4 of 8 Old 06-03-2013, 10:32 PM Thread Starter
Thanks Simone! Where is your valve on your system? If it is in bed and you did the test you suggest. Did you see diesel clear back to valve in 5 seconds? I have been purging for about 10 seconds and drivin for about a 1.5-2 minutes up my rd. guess that's plenty? Been conservative as my last system was significantly longer. Are you running 2 check valves? Thanks for your help!
mmmkay is offline
post #5 of 8 Old 06-04-2013, 07:37 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
Run time should be more than a minute, like at least 90 seconds. I have mine set to run 2 minutes and this allows my turbo to cool plenty.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #6 of 8 Old 06-04-2013, 04:29 PM
simone0414's Avatar
That was just a guesstimate on run time. I have actually never timed it. I just know where I need to switch over & how long to purge before I get home. My purge valve is located under the drivers seat on the frame rail just ahead of the VO filter. You should have no problems with your purge & run time.
post #7 of 8 Old 06-06-2013, 10:33 AM Thread Starter
Thanks for the feedback, much appreciated!
I would imagine that if I wanted a full bring I'd be longer than the 10 seconds it takes when valve is positioned on rail under cab. I'll play around with it. Thanks!
mmmkay is offline
post #8 of 8 Old 06-06-2013, 01:13 PM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
You would be suprised how much fule flow you get in 10 seconds.
