Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Bio-Diesel/Alternative Fuels and Supplements
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
  #41 (permalink)
Old 12-05-2008, 11:30 AM
Cory S Cory S is offline
here is how i collect i have a forklift so it makes this possible i have a transfer pump and battery in my bed. we have 4 1000 gal holding tanks i will take a couple pics of our system and tanks
  #42 (permalink)
Old 12-05-2008, 12:24 PM
ridiculously_necessary ridiculously_necessary is offline
Originally Posted by thelittle289 View Post
One thing about getting it right fromthe tank, all the trash is settled at the bottomin the morning. The restraunt I get it form has some one who collects it but the restraunt is family owned so he'll just have to get over it. Around here they only give .05 a gallon so if your detrmined I sure you could under cut them with very little effort if you had your own tank out for collection.
P.S. I run straight oil no bio processe no preheating. I mix 1 gallon of diesel to 4 gallons of oil and have a home made flitering system before it ever goes through the fuel pump. I have 2 tanks, I start on straight diesel and after warm up switch to oil, and before shut off I switch back to diesel to clear the injectors. Been doing this for 9 months with no problems, starts right up every time.
sure its .05 a gallon? around here i thought it was .09 a gallon and it turned out to be .09 a lb.
  #43 (permalink)
Old 12-05-2008, 12:28 PM
where do you live? do you collect pho too or are you lucky enough to have straight liquid wvo?
  #44 (permalink)
Old 01-09-2009, 06:57 AM
billman billman is offline
sucker tank is the only way to go in cold north east temps. My rest. dumps into 55 gal drums outside for me. I used the 12v pump till it got too thick. Unless you are in to moving heavy barrels you should consider the sucker.
There are plans on the web for sale.... I was able to build mine with a little research.
Tip: Find out where the propane companies send their tanks for reconditioning and contact them. I was able to pick up a 420# propane tank for $15 and the rest can be picked up at a local tractor supply, plumbing outfit......
Anyone that wants info it is pretty basic. email me wj.knight@yahoo.com
