Tips for installing push lock fittings - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 5 Old 05-06-2013, 08:15 PM Thread Starter
After installing a total of 4 3/8 push lock fittings while plumbing the veg lines into open ports on my 02 psd. I am hoping someone has a tried and true technique for getting barbs on hose. I tried light oil and hot water and it was still a PITA! I have about 10 more to go so any advise would be greatly appreciated! Thanks in advance for any suggestions, matt
mmmkay is offline
post #2 of 5 Old 05-09-2013, 03:44 PM
timmyboy76's Avatar
i used hose clamps, for assurance. had same problem as you.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 5 Old 05-12-2013, 05:19 AM
ACC
Snug (dont crush) the hose in a vice with just enough extended to accept the barb, with a rubber mallet or a plastic deadblow hammer drive in the fitting.
A little grease on the inside of the hose will help.
Tom
95 F250XL PSD SuperCab, BTS E4OD with a 6.0 31 row cooler, TS 6 position with Gearhead Tunes, Downpipe, Vegistroke V3, Tymar Intake, Autometer gauges, Gutted EBPV, Tymar Coolant Filter, Crystal Headlights, AC Mod, OilGuard Bypass, Stage 1's, Adrenaline HPOP, 370k and still Smokin.
Early 99 XLT SuperCab Auto, 4" Exhaust, DIY Tymar, Autometer Gauges, PMT2 ECU
ACC is offline
post #4 of 5 Old 05-29-2013, 10:56 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
All you have to do is use some alcohol, windex, spit etc and apply it to the barb. Then put the fitting on a desk or something, barb up. Then push the hose down onto the fitting. Usually takes two pushes. I install them all day long like this, not a problem. I know the post is a bit back, but someone else might ask the same thing.
MrOneEyedBoh is offline
post #5 of 5 Old 06-06-2013, 09:38 AM Thread Starter
Thanks for the ideas. I ended up using pot of water at close to boil for 10-15 seconds, put a thin application of motor oil on barbs and they went on with ease.
mmmkay is offline
