need new purge valve - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 9 Old 04-26-2013, 02:25 PM Thread Starter
I need a 2 port solenoid valve. I have gone thru 2 and want to get one that will last. any preference? thanks
02crew is offline
post #2 of 9 Old 05-03-2013, 07:39 AM
timmyboy76's Avatar
duda diesel
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 9 Old 05-11-2013, 04:40 PM
I had problems with valves as well. Here's what I ended up with:
1 2" 230 PSI Electric Solenoid Valve 12 V DC Viton B22V | eBay
It's kind of a pain to mount but It works awsome. Ive had it on the truck for a year and a half and its worked awsome
speedtuner is offline
post #4 of 9 Old 05-11-2013, 08:13 PM
The above valve is the correct spec and materials, EXCEPT brass should be avoided if possible. VO reacts with the brass, and creates a blue/green slime.
Otherwise its specs are just what ya are looking for in a purge valve.
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
The Following User Says Thank You to vegginpsd For This Useful Post:
Abitibi (11-25-2013)
post #5 of 9 Old 05-12-2013, 12:04 PM
I agree, but I used it because 1 is works, 2 its after the rail its not quite as big of a concern, 3 Ive gone through 3 other valves at this point that all failed(the plastic delrin crack and dump diesel everywhere externally), I needed something that worked & 4 Ive taken it apart multiple times and its as clean as a whistle. I think it stays clean because it gets flushed with diesel regularily and usually is sitting diesel not wvo.
post #6 of 9 Old 05-13-2013, 10:42 AM
timmyboy76's Avatar
here's this one, for 3 buks more...
1 2" NPT 12VDC 230 PSI Stainless N C Electric Solenoid Valve 12 Volt DC S22V | eBay
post #7 of 9 Old 05-13-2013, 02:48 PM
Originally Posted by timmyboy76 View Post
Thats seems like the perfect option. Great find! I don't think they offered it in stainless 1 1/2yrs ago when I bought mine, maybe I just didn't see it.
post #8 of 9 Old 05-15-2013, 10:15 PM
Quoted: 3 Post(s)
greasecar has some 2 and 3 port aluminum valves with warranties.
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #9 of 9 Old 05-22-2013, 08:26 AM
tubular031's Avatar
Have you looked at the valve wvo designs sells?
I am using a mcmaster valve. I had one leak after 2-3 years and replaced it with the same one. I think they were about 30 bucks. If this one fails I will try one from wvo designs.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
