wvo designs "kit' questions - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 7 Old 04-16-2013, 10:00 PM Thread Starter
hello,
i am posting to see if anyone can offer some help with the return/purge configuration i would like to do. i am in the process of installing the kit that wvo designs offers on their site along with their parts. i would like to keep pump, filter, fphe and purge valve back in the bed. i have previously had a system where the pump and filter were mounted on the drivers side rail and realized that the exposure (in my climate) to those components caused excessive and (maybe) unnecessary wear. my hope is to have everything under the protection of my topper where i have a 60 gallon tank that i had welded up with some mounting brackets on the side. i did not however have a return port welded in and am wondering if i can T my return back to supply line in front of pump or? i would imagine others have done this type of set up and i would love some ideas and or direction. i have never posted anything here but have used this site and forum for my own education for several years. any help/suggestions would be greatly appreciated! thanks, matt
mmmkay is offline
post #2 of 7 Old 04-17-2013, 05:40 AM
Use a purge valve (hydraforce two port 12v). Place a tee on the pressure side of the pump, after the check valve. Put the purge valve in and route to the suction side of the pump.
All the purge valve will do is route fuel around the check valve for purge. This, assuming the VO side of the system is dead head, using the pump regulator....
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #3 of 7 Old 04-17-2013, 07:27 PM Thread Starter
thanks for reply! the system is a dead head. could i use the 3 way valve i bought from wvo? i would also have to T into vacuum side as well right (2 T's total)? then everything upstream from purge valve would dead head correct? the valve would just re route and discontinue veg supply from right there at pump? would this make for a long purge time? would i use a "momentary on" rocker switch with this set up? sorry man i am one of those dudes who needs schematics or im useless! last question for now. would the best configuration for flow from heated pick up be: (pump - filter - purge valve - fphe) and off to engine? thanks for your help, i appreciate it and obviously need it!
mmmkay is offline
post #4 of 7 Old 04-18-2013, 04:10 AM
Originally Posted by mmmkay View Post
thanks for reply! the system is a dead head. could i use the 3 way valve i bought from wvo? I suppose you could, but you would need to put a pipe plug in the N/O port......
i would also have to T into vacuum side as well right (2 T's total)? YES then everything upstream from purge valve would dead head correct? YES
the valve would just re route and discontinue veg supply from right there at pump? YES
would this make for a long purge time? NO, purge time is dependant on the length of fuel hose. I would say your purge time would be less than 30 seconds. would i use a "momentary on" rocker switch with this set up?
sorry man i am one of those dudes who needs schematics or im useless! Its cool, thats what we are here for!
last question for now. would the best configuration for flow from heated pick up be: (pump - filter - purge valve - fphe) and off to engine? thanks for your help, i appreciate it and obviously need it! That is correct. Pressurize filter and FPHE..
Replies above.
99 F350 7.3
B100 by Biopro 190
post #5 of 7 Old 04-18-2013, 09:09 PM Thread Starter
lastly (for now). this system will be non automated or controlled. would the purge valve be controlled best by a momentary on/off rocker switch? thanks again for the help vegginpsd, it is greatly appreciated!
mmmkay is offline
post #6 of 7 Old 04-19-2013, 04:34 PM
simone0414's Avatar
That`s what I use.
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #7 of 7 Old 04-20-2013, 10:08 AM Thread Starter
cool thanks simone0414!
mmmkay is offline
