DIY setup purge times - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 3 Old 03-31-2013, 04:34 AM Thread Starter
rosshurlow1's Avatar
How long do you guys with DIY set ups purge before turning off and do you guys know a good source to find a resource for a DIY setup for a 02?
rosshurlow1 is offline
post #2 of 3 Old 03-31-2013, 05:55 AM
purge time is largely dependant on many different variables. The best way to determine purge time is to look at the VO pickup line, and purge until diesel is present. Just watch inside the tank with the purge valve open until you are sure diesel is present.
Look at the sticky's on top of the page in this section. There is a lot of good info there.
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #3 of 3 Old 03-31-2013, 02:26 PM
simone0414's Avatar
I have my temp gauge plumbed right after my FPHE. So I know I have purged long enough when I see my temp gauge start to drop. That takes about 5 seconds. Then I run her for about 90 seconds & shut her down.
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
