WVO STORAGE???'s - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 4 Old 03-23-2013, 10:55 AM Thread Starter
vandy's Avatar
WVO STORAGE???'s
Ive got 4 55 gal steel barrels. They were used to hold clean new motor oil. I'm sure there's atleast residue if not a qt or 2 still in them.
My question is how well will they work to hold/settle wvo?
Do i need to get all the motor oil out first?
Is it true there is a coating in the inside that will resist poly build up?
If i need to get the motor oil out first, what's a good way to do this?
Any other thought or knowledge from experience is appreciated
Thanks
Vandy
vandy is offline
post #2 of 4 Old 03-23-2013, 05:45 PM
Vandy
I just dont think what you described is a really good idea.
You best bet is probably an IMC tote.
Steel barrels have value. Sell them and buy an IBC tote. They usually run $50. I recomend checking craigslist.
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #3 of 4 Old 03-23-2013, 07:07 PM
Quoted: 3 Post(s)
good steel barrels with removable lid will have a tan coating on the inside. Empty what you can out and then just wipe the rest clean with a rag and that will be fine.
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #4 of 4 Old 03-24-2013, 03:46 AM Thread Starter
vandy's Avatar
Re: WVO STORAGE???'s
Ive got a 250 gal tote for clean oil. These would be just to hold dirty oil until i can clean it.
Unfortunately they do not have a removable lid. So i don't know if they have a coating or not
Like i said they were free so I'm not out anything. I'm just unsure if i should use them or not
vandy is offline
