Rev-X information - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 03-05-2013, 05:21 PM
Rev-X information
I have a 2004 6.0 that starts quite rough and well I was considering adding Rev-x. The problem is I have no clue how often each "treatment" will last because it is quite expensive and I don't want to add this all the time.
If you can help me out with this please do, also what particular product should I get?
Thank you.
Old 03-06-2013, 04:33 AM
Here is what I use.
AR9100-Nanoborate, nano technology, friction modifier, friction modifier for engines, gear boxes, transmissions, generators, reduce friction, save energy, double oil drains, stiction, injector stiction, carbon buildup, ford powerstroke, - Archoil
I change HPOP oil every oil change (5000 miles), with the additive every other oil change (10,000 miles). I add to the emptied HPOP resovoir, and top off with engine oil, then fill crankcase.
Old 03-06-2013, 04:37 AM
Just add two bottles to your oil when you do an oil change and leave it in there for the duration, some add one bottle every oil change after that. Are you sure it's the injectors and not the FICM?
Old 03-06-2013, 05:19 AM
t5 with archoil made a big diffrence in my cold morning starting issues. Dont know if Ill need to go with the Rev X but if this stuff "wears off/out" Ill give that a try. Pouring a bottle of snake oil in the truck is a lot more fun than spending the weekend cramped up pulling injectors...
Old 03-11-2013, 02:53 PM
Check FICM Just replace mine and truck is like new again
Old 03-13-2013, 05:43 PM
I just purchased a Scangauge II and I have been monitoring my FICM voltage. It's good. Lowest i saw was 47.5 volts. So it must be the injector stiction. Although I just replaced all 8 of them.
Old 03-13-2013, 05:44 PM
Yes I'm sure. My FICM is fine, I've been monitoring it on my Scangauge II. Lowest voltage it's gotten to was 47.5
Old 03-31-2013, 06:18 AM
The Rev-X will work great two bottles and my cold start problems 100% better. I had tried Hot Secret before because it was cheaper but had no luck with it.
Old 03-31-2013, 07:04 AM
Rev-X= Stiction Gone!
Old 03-31-2013, 07:10 AM
Chapter Director
I love Rex x have used it 2 time now great results
