Running Bio without modifican - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 02-04-2013, 12:03 PM
I'm looking at getting a 6.4 in the spring/summer and I'm wondering if I can run wvo mixed like B20 or B50 just by pouring it in the fuel tank without modifying the truck to run it is that a possibility? Is it even possible to run B20 in a 6.4 or what?!
Old 02-04-2013, 12:23 PM
Im confused.
You asked about running wvo then said B20 or B50....
B20 is 80% D2 and 20% Biodiesel
B50 is 50% D2 and 50% Biodiesel
WVO is waste vegetable oil.
I dont own a 6.4, but if memory serves, the mnual says something like B5 or B10. I would, however, not have a problem B20 or slightly greater if the wether was consistant with operation.
I would never recomend WVO mixed with d2 in that engine or any other, if that helps answer your question.
Old 02-04-2013, 12:29 PM
I thought B20 was WVO mixed with diesel and made it biodiesel like I said Im pretty green on this subject I read a few threads last night and Okay Ill take your advice and steer away from wvo mixed with diesel
Old 02-04-2013, 12:36 PM
Cool.
If it is biodiesel, then Yes, it would be fine. WVO, mixing would likely cause more damage and expense than you could possibly save.
Stick around though. There are a lot of knowledgeable guys hanging around here, and they too likely will chime in.
Old 03-04-2013, 09:24 PM
WVO is waste vegetable oil. That means it has had some sort of interaction with cooking already. I make biofuel (commercially) from canola/soya depending on which is cheaper but this is virgin....crushed and extracted straight from seed.
Any truck after 94 should be fine to run on B100. The majority of manufacturers upgraded their seals at this point to Viton. I have a 96 and have been running B100 for 2 years with no problems. Only thing that you may encounter (apart from the gelling at -2 to -7 depending on raw material) is a clogged filter. This is a result from the biofuel being a natural cleaner and can agitate the sediment in the fuel tanks from the dirty diesel so carry around a spare filter.
Old 03-05-2013, 04:12 AM
This is a temp in Celcius, unless Rob knows something revolutionary and will soon become a millionaire (or disappear forever )
Big oil would be interrsted in "having a chat" if B100 gets temperature stabilized below 0*F!
Old 03-05-2013, 07:02 AM
I wish I did know something different! I have been making this stuff for over 10 years now. My company is the main supplier to Chevron up here in BC.
To make things interesting and if you do have trouble with temperatures I your region then naturally blend with either diesel or I have used paint thinner (10% blend) but depends what is cheaper at that time.
I only got stuck one time in the 2 years running B100 in this truck when we had an unexpected cold snap of -7C which have me a fuel filter warning immediately. Quick drive to gas station and mix solved my issue! (I did have to change out the filter though)
