| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
Injectors? maybe a dumb question
I've been researching wvo and bio-fuel for about a year now. I bought a 01 7.3 in october and am currently modding it for pump fuel but plan on converting to wvo in the next year to year and a half.
Does injector size effect anything in the use of wvo. I plan on getting 205cc/100% injectors but do not want to have to replace them when I convert. Any info or a link to a page with info will be greatly appreciated. Thanks, Adam |
Having a similar set up, (see signature) my only thought when having done this was to make sure the VO side is a minimum of 5/16 fuel line to the heads. I ran 3/8 from the filter all the way to the heads with a R/R and I have plenty of fuel.
Is a R/R a necessity or will a FRx work? Do have one fuel tank you or have a aux. tank for your B100? Would you suggest a kit from vegistroke or am I better off building my own? My build budget is basically work overtime buy parts once everything is aquired build.
I see in you sig that you have a simple centrifuge and a bio pro 190. Did you start with the centrifuge and upgrade to the bio pro 190? From my understanding which is basically read on simple centrifuge's website and what you and snake's posts on the forum. You can use the wvo directly out of the simple centrifuge for fuel correct? Or is something like the bio pro 190 required?
The Biopro190 is a Biodiesel reactor. I no longer burn WVO, and have switched to B100 Biodiesel. here is a link to the Biopro Bio Pro 190 Stainless Steel Automated Biodiesel Processor - Make 50 Gallons Of Biodiesel With Ease! Metal Biodiesel Processor - Utah Biodiesel Supply |
Thank you for your help, and that link for Bio Pro. I guess in the next year or so I have alot of decisions to make with bio-fuel.
First step is to decide if you want to run WVO or B100. Your conversion, and processing needs will be significantly different. |
Currently leaning towards a Bio Pro system. Seems to what I have read on there website there is minimal alteration I need to do to my truck other then a heated fuel tank. My father also own a business with loading docks and fork lift so I can buy methonal,potassium hydroxide/sodium hydroxide, and sulfuric acid in bulk. Also it sounds like I can use B100 as a replacement for K1 easier then wvo in my furnace. Either system seems to be a good investment though.
I switched to B100, and will never run WVO again. There is no finer machine to produce quality biodiesel with respect to ease and time than the Biopro's, in my opinion. If you get one, hit me up. There are a few little known secrets, that make a big difference in production that I would be happy to share with you. |
