| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
Decrease In MPGs With BioDiesel B20?
Any one notice a decrease in MPGs while running BioDiesel B20? I ran a hand full of tanks of B20 and seemed to get better MPGs with regular diesel+2 stroke oil. If I remeber correctly regular diesel burns hotter than BioDiesel? I like the fact of BioDiesel cleans the fuel system and not having to add 2 stroke oil but probaly wont run it again due to MPGs
I'm a huge proponent of biodiesel but yes, I noticed a pretty good drop in MPG running B20 and beyond. It's not a huge drop, but if you are paying any more for the B20 than normal fuel - not worth it IMO. I run it now and then, to clean things out, but that's it.
Good luck - Scott |
it is cheaper or the same as regular diesel
It has a lower calorific value, same as wvo - have you tried a cetane improver
I saw roughly the same MPG with B20 and running DieselKleen at the same time. Around here the Biodiesel price drops lag dino-diesel. At times, it's .10/gal more. I'll run dino-diesel until the price catches up.
The difference between Quality B100 and D2 for me is negligible. The difference between B100 and WVO is tremendous in my vehicles. I will never run WVO again, ever.....Thats a whole different debate. Sorry if I am hijacking. |
I have read numerous reports on alternative diesel fuel forums of a loss in mileage when burning biodiesel at even as low a concentration as B20, regardless of the diesel engine running it. So, I am curious, vegginpsd, when you run B100, are you running it in your heated two-tanks system. If so, then heating biodiesel might be the solution for improving its combustion in a diesel engine. |
vegginpsd - we used to have BTU but going metric changed a lot of measurements - having said that I still think inches/feet and pounds/hundredweights
Yes, ardlanish, going metric means we are now talking about joules/Liter, or per kilogram, but I was raised both in the USA and in the British Common Wealth, so I am familiar with chains, roods furlongs, penny-weights, drams, etc. as well.
I think vegginpsd is on to something burning biodiesel in a heated fuel system. It is common practice in Europe to install a flat plate heat exchanger (FPHE) to improve the combustion of WVO and biodiesel. Perhaps it should become common practice here as well. |
I dont think it makes two squirts of piss (pardon the blending pun)difference EXCEPT one major factor....which may come as a surpise to a guy living in the dessert... Biodiesel gels at +/- 32*F. This morning at -11*F, traveling at 60 MPH I dont think I could develope 65 PSI and have adequate volume any other way but a heated system. A 100 FPHE would not be the answer either. A heated tank, TIH and a good pump and hot filter is required. In addition, in temps sustained over 32*F, I merely turn a ball valve on the system and cut the heat (coolant). SOOOOOOOO, with temps above the gel point, heat is not required. Thus I dont believe your theory means a damn thing. Sure wish I could say I missed you in your all too brief absence, Jeff, because I didnt, not even a lil bit. Last edited by vegginpsd; 01-05-2013 at 08:14 PM. Reason: spelling |
