Farmer makes diesle fuel by blending gasoline with vegetable oil - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 3 Old 11-16-2012, 03:51 AM Thread Starter
Farmer using sunflower oil mixed with gasoline on his farm vehicles, using
specific gravity as his blend indicator
Daniel (sodbust) McAmoil
Bio-Diesel: Farm Grown Profit
Daniel's data
Fuel mix, temperature, specific gravity
50% gas/50% sunflower oil mix at -20f (-29c) has a specific gravity of .850
12.5% gas/87.5% sunflower oil mix at 75f (24c) has a specific gravity of .870
12.5% gas/87.5% sunflower oil mix at 170f (76.7c) has a specific gravity of .850
12.5% gas/87.5% sunflower oil mix at 190f (87.8c) has a specific gravity of .840
"I'm just using unleaded gas to thin the sunflower oil to match the thickness of #2 diesel so the injectors can do a good job of fogging it into the engine. I use a hydrometer calibrated from .820 to .890. Normal #2 diesel floats the hydrometer at around .850 to .865. ((I'm finding that most of the diesel fuel I'm getting this summer is down to .820 which tells me we are getting allot of jet fuel blended into our #2 diesel)). I just press, filter, add gas and go. No chemicals, washing oil, drying oil, or any engine adjustments, just as simple as
can be!"
"Every engine that I have used it in gains at least if not more than 25% power, and fuel mileage. My new R75 Gleaner with a M11 Cummins used 1 gallon an acre on regular #2 diesel, in comparison, on sunflower fuel, it uses just a tad over 1/2 gallon per acre. My '98 Dodge Pickup went from 16mpg with #2 diesel up to 24-26mpg on sunflower fuel. It's unbelievable!"
"I am sitting out here with 3/4 a million dollar rolling stock fleet and I would have to shoot off the hip to show gallons and amounts of super fuel ran in each.. I can list the items that run and run well and then would have to try and divide the total amount of fuel made between them over the years and the percent of blend or full amount of super fuel, almost impossible.
But I can say the first year with my fuel plant running,,,,, all of them ran year round the first year (365 days) on 100% home made fuel. I would guess somewhere around 28,000 to 30,000 gallons to date.
1978 Case 1070 1500 hours
Ford TW145 500 hours
Agco white 5.7 Cummins 650 hours
2007 R75 Gleaner with a M11 Cummins.. 2000 hours
7130 Case/Ih tractor with the 8.4L Cummins 1200 hours
1965 white truck with the C180 Cummins 20,000 miles
1995 KW semi with the 11L Detroit 80,000 miles
1998 Dodge ram with the 5.7L Cummins 100,000 miles
846 Ford with the L10 Cummins 3500 hours
1978 750 Versatile with the 855 small cam Cummins 2200 hours
1975 555 Versatile with the big cam 855 Cummins 1800 hours
1938 D4 Cat 200 hours
25/2,12/2,20/2,15/1,6/1 Lister ( Indian clone Listeroids) 2500 hours
87 MT 250 Mitsubishi 500 hours
This covers the diesels running on the farm other than a few water pump air cooled diesels.. We do add 8 to 12 oz. of supper fuel to all our gas engines with full tanks over 20 gallons as an upper cylinder lube,, but one has to be real careful as they donít burn the oil a clean as a diesel and can carbon a gas engine up to the point of sticking the piston rings.
Hope this helps
Daniel"
beyondbiodiesel is offline
post #2 of 3 Old 01-04-2013, 04:10 AM
HOW BIG IS YOUR FUEL MAKING OPERATION? ANYONE DOING THIS IN OR NEAR GEORGIA? ABOUT HOW MUCH PER GALLON? ALOT OF GOOD AND BAD TALK ABOUT DIFFERENT BIO DIESELS ON THE WEB. IS IT REALLY WORTH THE RISKS OR DAMAGE TO YOUR DIESEL? ARE THERE PEOPLE OUT THERE SELLING GOOD CLEAN BIODIESEL N THE SOUTH THAT U DONT HAVE TO WORRY ABOUT PROBLEMS OR TONS OF MAINTINENCE
8SECNOTCH is offline
post #3 of 3 Old 01-04-2013, 04:42 AM Thread Starter
I make waste oil based diesel fuel in 20 gallon batches. I do not know how large a batch Daniel (sodbust) McAmoil makes, but I get the impression from my communications with him that, at least at one time, is batches were made in 55-gallon drums.
I do not know.
Cost per gallon tends to depend upon one's methods and the cost of the source waste oil. I have made all of my filters back-flush-able, so I have not had to replace a processing or fuel filter in over 2 years. My waste oil cost is typical $0, so the only cost for me in making fuel is the cost of the gasoline that I blend with my waste oil to make diesel fuel, which is 20% at about $3/gal, so that comes to 60c per gallon.
If you are asking how much Daniel or I would sell fuel for, well, neither of us are the business of selling fuel.
I agree there are a lot of reports of bad biodiesel being sold by fuel stations, so most people make their own, and they have varying methods of burning waste oil as diesel fuel. Some methods work better than others, and the requirements for the consumer are variable as well, so one method may not work for all applications. Therefore, it is useful to have some open dialog about methods and practices, so that we can all improve our product.
