What to do with the waste fluid? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 05-09-2012, 04:55 AM
What do you do with all your waste fluid after you wash the biodiesel?
Old 05-09-2012, 12:10 PM
Right down the drain
Old 05-09-2012, 01:57 PM
Isn't it hazardous though? Glycerine, methanol, phosphates?
Old 05-09-2012, 05:04 PM
You asked about water wash. Unless you have developed a new way to wash with glycerine, methanol, and phoshate, water wash is WATER.
Yes, some residual methanol and trace glycerine will be present. It wont harm a thing, especially in a municipal system.
Old 05-10-2012, 07:57 AM
Ok, just wondering. I didn't know how much glycerine comes out. I have a septic system.
Old 05-10-2012, 04:20 PM
Well, then you will have clean pipes!
Water and glycerine make a wonderful cleaner/degreaser. Not necessarily in the ration that it will occur in the wash water, but none the less.
Here are some other uses for glycerol (long read, but sort thru it)
101 Uses For Biodiesel - Topic
One that may not be in the link provided, is that glycerol blended with 50% WMO works well in atomizing furnaces, I.e Cleanburn, etc.
When heated above 140, the mix flows well and produces a tremendous amount of BTU's, for virtually FREE.
Old 05-14-2012, 06:48 PM
i could be way off my rocker here, but when i was looking into playing with bio, the best idea i had read about was basically taking the wase, be it wash water or the by product and boil the hell outta it (turkey frier would work well) from what i was reading the liquid was the hazard issue and it was "ok" to have it evap, and you could trash the solid waste no questions asked
Old 05-17-2012, 03:11 PM
Not entirely accurate, but close.
If using potasium hydroxide it can be composted, if demthed first.
Bioling of of methanol in open air is probably not wise. If you are going to heat the glycerol, you could just as well distill it, and reuse it.
