Bad b20 blend ? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 10 Old 05-08-2012, 08:20 PM Thread Starter
JR3342's Avatar
Bad b20 blend ?
The pics are from the fuel bowl of a 2012 Pete. 3 Weeks old 11k miles. Most of the fuel from same truck stop in Florence sc. Supposed to be a b20 blend. Smells stronger. Any guesses what the white flakes are ? This place is known for causing fuel filters to plug. Company continues to want trucks fuelled there for the large discount. This is strangest thing I've see. In a while.
Sent from my DROID BIONIC
ID:	37778   Click image for larger version
JR3342 is offline
post #2 of 10 Old 05-09-2012, 03:48 AM
Its difficult to see with the photo, but it looks to me like it could be soap.
Again, it difficult to see from the photo.
If I mixed up B20, you would never know there is any biodiesel in the blend. Is a sweet smell you are detecting?
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #3 of 10 Old 05-09-2012, 04:24 AM Thread Starter
JR3342's Avatar
It smells like straight veggie when it Burns. Looks like snow in the bowl and the filter has dandruff.
JR3342 is offline
post #4 of 10 Old 05-09-2012, 02:43 PM
Try this....
Put in in the fridge next to where you keep the wobbly pops.....get it down to 32, or less.
A couple things could happen. Here is a couple things:
The white stuff could percipitate out
It could cloud
It could begin to gel
With one r more oof the above three conditions occuring, it may lead to the root of the problem.
99 F350 7.3
B100 by Biopro 190
post #5 of 10 Old 05-28-2012, 11:25 AM Thread Starter
JR3342's Avatar
Got home finally. Drained the fuel bowl into a jar. Put it in the fridge. 30 mins into it fuel turned milky yellow , white flaky crud in the middle, and dropped a bottom layer of brown watery looking goo.
JR3342 is offline
post #6 of 10 Old 05-28-2012, 12:23 PM
I would be taking that jar (cold) back to the retailer you purchase the fuel from. Lord only knows what went thru your pump and injectors......
99 F350 7.3
B100 by Biopro 190
post #7 of 10 Old 05-28-2012, 01:38 PM Thread Starter
JR3342's Avatar
A few hrs in freezer. Fuel layer Verry cloudy. Bottom layer froze solid.
JR3342 is offline
post #8 of 10 Old 05-28-2012, 01:41 PM Thread Starter
JR3342's Avatar
ID:	38489   Click image for larger version
JR3342 is offline
post #9 of 10 Old 05-29-2012, 05:08 PM
Under reacted fuel. Looks like it may have some soap too.
Poor quality biodiesel. Very poor. Steer clear: Far and wide.
99 F350 7.3
B100 by Biopro 190
post #10 of 10 Old 05-29-2012, 06:59 PM Thread Starter
JR3342's Avatar
It's from the Florence sc. Area anyone traveling i95 be careful where you fuel. It came from largest truck stop chain. I got to fuel there company chosen fuel stop. Luckily all engine parts warrantied to 500k injectors included.
JR3342 is offline
