Couple quick wvo question on 6.0 - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 05-06-2012, 02:30 PM
I understand idleing is bad but what about with high idle and what about just 10 mins is that to long ? thanks guys
Old 05-06-2012, 07:21 PM
If you are going to idle, you may want to consider purging it before you do, at any RPM.
While considering a WVO conversion on the 6.0, proceed with caution. Individual results will vary.
Old 05-14-2012, 10:58 PM
what do you mean by "proceed with caution"
Old 05-16-2012, 04:52 PM
Idle is bad? Just on the 6.0? More info plz
Old 05-17-2012, 02:47 AM
I think he means that the 6.0 is more proned to problems on any fuel. Blown headgaskets, EGR problems, injector problems. Injectors are more sensitive then the 7.3. So clean dewatered VO at the correct fuel pressure at the right temp ( 160F or better) is very important.
Old 05-17-2012, 02:50 AM
Idling on VO is not a good thing on any engine. Diesels don't run very hot when idling so the chance of unburnt fuel deposits increase. This doesn't mean you cannot idle at all but just don't do it for long periods of time.
Old 05-17-2012, 03:42 AM
What is wvo? Sorry for the dumb question
Old 05-17-2012, 04:17 AM
Waste vegetable oil.....I'm the king if dumb questions ....no worries
