WVO in an OBS - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 23 Old 03-11-2012, 03:52 AM Thread Starter
vandy's Avatar
WVO in an OBS
I have been looking for a ford diesel for a while to do a wvo kit on for a while. About 10pm I get a phone call from a guy looking to trade me his 95 7.3L for my k5 GMC. What all is involved with the swap. I've read about needing the newer electric fuel pumps and modifying the fuel bowl. I'm gonna check this truck out but if its running good ill prob do the swap
vandy is offline
post #2 of 23 Old 03-11-2012, 06:57 PM
Aaron Berk's Avatar
There isn't "allot" involved but it is a critical process. Do it right, do it once.
I prefer to run 2 totally separate fuel systems, including separate fuel pumps and filters.
Converting your truck on the cheap, will only get you problems further down the road.
Read every post in here, and then read them again.
Lots of good info to be had.
97 F250 ext cab lwb 4x2
AirDog2 and FASS HD (it's a WVO RR setup)
Simple Centrifuge filtering method
203 degree Mod, DIY homegrown intake, CCV mod, battery relocation,
215amp Ambulance Alt.
EBPV gut, Pedestal gut & cut
Diamond Eye 4" (3" dp) turbo back straight pipe
no kitty, no muffler
Aaron Berk is offline
post #3 of 23 Old 03-11-2012, 07:22 PM
Ummm
There is a sticky located on the very top of the page.
Otherwise this is it
Another DIY WVO Build
Its been done successfuly.
Otherwise buy a kit and get a qualified installer.
99 F350 7.3
320K w/ 150k+ on Biofuels
Casserly Stage 2's-TE Modded 17 HPOP
DP Tuner F6 & PMT1-Van Turbo Non EBPV & 6637
Twin Fass Pumps B100 & D2 Regulated Return- Fuel Lab
Isspro Pyro, Trans, Boost-Air and Fuel Temp
WVO processed by Simple Centrifuge
B100 by Biopro 190
B100 powered Excursion, F250 CCSB, and Two TDI Jettas
vegginpsd is offline
post #4 of 23 Old 03-11-2012, 07:34 PM Thread Starter
vandy's Avatar
I guess my big question is with the vegistroke kit to be on an OBS there are some mods to the kit/truck fuel pump and bowl. Frybrid makes a kit for the OBS I can't find much info on it other than its half the price. I'm not so worried about the cost as I am having a solid set up. I've been reading a lot. Lot of good info. Sometimes u get a better response by asking
vandy is offline
post #5 of 23 Old 03-11-2012, 07:37 PM
atvrider93's Avatar
Quoted: 8 Post(s)
I take it you're wanting to run on straight WVO? I''m running mine at around 30-50% with no modification at all
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #6 of 23 Old 03-11-2012, 07:42 PM Thread Starter
vandy's Avatar
first off nice rig!!!!!
see thats why i ask questions. this is the first ive heard of this also. so you are just using as a fuel additive basically?
i try to search as much as i can but 99% of my internet searching is done via cell phone so it has its limitations. if i spend a day or so searching i start asking. i seem to find more and more variations of how people are running this stuff
vandy is offline
post #7 of 23 Old 03-11-2012, 07:45 PM
atvrider93's Avatar
Quoted: 8 Post(s)
Thanks!
Ya basically. I don't run that much consistently, its more as I get it and as I have time to filter it. In colder months I don't use much but when it's warmer I do as much as 50% and it handles it fine. I change my fuel filter every 10K because it will definitely clog up quicker with WVO
6637
OBA w/horn
DE 5"
PHP tunes
2008 Wr250X
post #8 of 23 Old 03-11-2012, 07:53 PM Thread Starter
vandy's Avatar
thats interesting ive always read not to let them mix, or wvo sit in the injectors
vandy is offline
post #9 of 23 Old 03-11-2012, 08:23 PM
simone0414's Avatar
Frybrids kit may be cheaper but you will wait forever to get them. Customer service is terrible.
The best way to run SVO is to keep it out of your stock system.
2001 f-350 ext.cab. 7.3 auto non dually. 262k miles. New HD tranny at 67,000 miles. Boost, EGT, Tranny temp gauges. 04/10 DIY check valve VO conversion. 20 plate FPHE,Fass HPFP set at 70 PSI,TIH, 10 micron spin on filter with coolant wrap, 150 micron prefilter, hrydraforce purge valve, 40 gallon greasecar tank with hotfox, SS braided hose to heads, Oil temp, pressure & fuel level gauges. 110K miles on grease.
Monitoring with Torque.
simone0414 is offline
post #10 of 23 Old 03-12-2012, 03:17 AM
Not a good idea.
Yes sir. THats the way to do it right. Your heads, injectors and rings will love you for it.
99 F350 7.3
B100 by Biopro 190
