| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
What to do
Someone added wmo to my wvo pickup tank. Looks like it is about one oil change worth. It is in with about 25 gal. of wvo. Do I filter and go ahead and burn as usual, or throw it out. I do not have a fuge, I use a 600, 400, 200, 100, 75 filter system then pump thru a 30, and then 2 micron filter and then goes into a hot water tank to heat and water separation. Then to truck.
I'm just glad I found it before going on. |
I would not use it.
What is wvo and wmo?
waste vegetable oil and waste motor oil
QUICKLY!
Find a Sanimax dumpster and donate it. WMO and WVO mix is not cool. It will turn into pudding. It is contaminated. |
Ok it's outa here
Thanks |
7.3? I say why the hell not!
no bueno
reegular dino oil and a wvo leak internally
Woodys Holds, LLC synthetic oil and wvo are worse enemies |
