wvo filter specs - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 02-28-2012, 06:47 AM
wvo filter specs
Building my filtration still. Trying to figure out my best cost effective set up for now and will be upgrading as my system needs. This filter set up to me should work. Its set up for plenty of pressure. I'm guessing my micron filtering is within spec. Before I pull the trigger I figured I'd post my specs
Thanks in advance
Vandy
Old 02-28-2012, 10:28 AM
Left out a link by chance?
Old 02-28-2012, 10:51 AM
Can y'all not see the pic with the specs? I don't have a link. Let me know if I need to preposterous the pic
Old 02-29-2012, 06:58 AM
ok I see it now, must have been a bug on my end.
The temp and pressure look fine.
Sounds like a small filter though.
And I like a higher micron rating personally
How is your flow diagram set up?
A few more details would be great, are you filtering under heat and pressure?
Don't be shy, spill your guts.........
Old 02-29-2012, 07:18 AM
Heat and pressure. Round 140 temp. Not sure on pressure yet. About the same set up as clays. With minor tweeks.
Why a higher micron rating? Isn't the smaller the number the "cleaner " the oil?
Maybe I'm not understanding that concept?
