| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
6 oil
so a buddy of mine works in an environmental company and gives me a call today saying that he's got TONS of #6 oil which im interpreting as crude oil, correct me if i am wrong.
My question is what would i have to do to my 99 7.3L to run this oil in my truck as fuel.. aside from filtering/dewatering'' and is it even possible |
Wow #6 is a pretty heavy bunker oil. Lot of undesirable crap in that!! Put it this way it's like boiling all the good burning fuel out of a barrel of oil and the one gallon of goop left over that looks like molasses is what #6 is like. The high mineral and coke content would probably be real hard on injectors.
so probably just go with regular oil / atf
I only burn diesel, what you burn is up to you. There are a lot of guys that burn alternate fuels that can chime in with their opinions, but IMO Bunker 6 is a garbage oil that's only good for spraying on gravel roads. If it was Bunker 4 or less I'd say give it a try.
I worked with 6 oil at a boiler plant. It is molasses at best. If that stuff is not over 100 degress good luck moving it. You would have to cut it with kerosene to about 5:1 if not more to get it thin enough. You would spend more money in kersoene that it is worth.
