Biodiesel blends? - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 11-07-2011, 06:40 AM
Biodiesel blends?
Now that I am making bio, what is the best blend to run? Are there any things I need to consider? (weather, % of blend etc.) I would like to run B100 as that would save me the most money. Is that safe? Are there any mods necessary.
'09 KR F250. Stock
Old 11-08-2011, 03:22 PM
No mods required & you can run b100 as long as it isn't too cold out. Bio gells alot quicker then D2 so if you live in flordia then you probably won't have a problem. If you live in Michigan then in the winter your going to have to mix it with D2 or when it gets real cold not run bio at all. Exactly what temps your will have to start changing your bio % I'm not sure. Some guys mix bio with a bit of RUG to keep it from gelling. It up to you if you are ok with doing that.
The only other thing that will happen is you will probably plug a couple filters. Bio will clean all the buildup & crap in your tank & lines. It won't hurt your engine just plug your filter. Carry a filter with you so you can change it when it happens.
Old 11-09-2011, 05:46 PM
Hillbilly Deluxe
Feedback Score: 3 reviews
Your gonna try bio in a 6.4?? I would do a lot more research before i would make that leap, But that's just me. I mean retail on you truck is probably something like 35k or so?? I would hit up clay and see how he's making out with the 6.4 vegistroke...
Let us know how you make out if you take the leap...
Old 11-10-2011, 09:07 AM
Can't hurt to double check but if BFT is working on a kit to run SVO in a 6.4 then I find it hard to beleive it can't run bio.
Old 11-10-2011, 11:06 AM
Ive been running B100 on my 04 6.0 for the past 4months.. runs great. I did run a full tank on a 08 6.4 and it was running fine. Then I was stuck in traffic for a min... and it started smoking. Thought it was the biodiesel. Its like the truck didn't want to boost all the way.. from what I read was the dpf... something about a self cleaning. Bt anyways it would smoke for a min. Then stop.. but it hasn't done it since I went back to regular diesel on the 08. So I don't know.. bt for sure it was a dpf issue from what I was reading.
Old 11-10-2011, 11:23 AM
I don't know nuttin....
Bio wont hurt your 6.4 and yes, I'm running 100% WVO in mine.
As for gel point, I recently had this discussion on the BFT forum with a guy in Nova Scotia running B100. He claims hes never seen it gel. Turns out this is entirely dependent on the feed stock used to make the fuel. The oil type he was getting apparently was not a feedstock that would gel at even -10*.
Get you a sample jar of your Bio, set it in the fridge, see if it gells, if not, set it in your freezer and I bet it does. My buddy used to make Bio and his would get at around 38*
Old 11-10-2011, 05:24 PM
Hillbilly Deluxe
Clays the man when it comes to this stuff...
