'96 PSD, 3 year update - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
Old 10-03-2011, 02:54 PM
3 year update.
I’m three years into this veg life and thought I would post a bit of an update. In 2008, I purchased a ’96 F-250 and installed a goldenfuels kit. Their customer service was great and their tanks are awesome. Turned out the kit didn’t really deliver, so that led to the overhaul of my system, posted here:
SVO Conversion: 1 Year update
And here:
Electric fuel system upgrade on veg conversion.
Thanks to a lot of help from guys here on the .org, I got a bomber system running. Since that time, my only hang-up has been with my purge valve. The first one I installed broke almost immediately. Leon (WVO designs) was awesome and replaced it for me under warranty. The second one lasted about 9 months before it seized and stuck open. I had purchased a spare, so I installed that one. However, I’ll probably buy a different valve the next time around.
The system is now at 65k SVO miles and I love it. Here are a few of my thoughts based on my experience. Not everyone will agree, that is fine.
1. The check valve based conversion is simple, elegant, and relatively bombproof. I think this is the way to go on a PSD and minimizes the number of parts prone to failure.
2. Get the burliest fuel pump you can. Anything less will get fried.
3. I love the Racor 1000 filters. Yes, the FASS can handle it on the vacuum side. Filters are cheap, the water block works (no it doesn’t filter water, just blocks it), and with my 3 tank system I can dumpster dive and use these filters when I need to.
4. Time is your friend with filtering oil. Centrifuges are sexy, but ultimately unnecessary. After a couple of weeks (in a decently warm garage) oil will settle out to 5 microns or so. Water is heavier than oil and sinks. I store my oil in a 330 gallon tote in my garage and pump off the top. Every once in a while I drain the manky funk off the bottom. Doesn’t get much more simple than that.
5. Coolant heat is better than electric heat. Every electric heating element I have used has failed. As long as the truck has coolant in it, my coolant heating works. I do a heated pickup, HOH for the fuel line, wrap my filter in coolant line (ouch, that’s 15 ft of line!), and use a big FPHE in the engine valley. I did add an aux coolant pump (not sure it’s needed on the 7.3 and would probably skip it next time to keep things simple), and it does take a few extra minutes to warm up in the winter. One thing I would add is a warm coolant circulator to run in the AM instead of a block heater.
6. Running veg will never be as easy as going to the pump. For me, it is absolutely worth it, but if you are thinking of getting into this, recognize that it does take some time, you will inevitably make a few messes, and none of us will design and install a system that will run without any hitches. There is some inevitable maintenance and repair that needs to be done at home because it’s not worth the time to explain the whole thing to a mechanic. That being said, I have avoided burning thousands of gallons of diesel and I’m proud of that. I’ve also saved myself over $15k in fuel costs (and that’s after recouping the expense of the veg parts) and that’s pretty awesome.
All in all, a great move and I deeply appreciate all the help I’ve had from folks here on the org!
Old 10-03-2011, 04:09 PM
Charlie, Great to hear about your success with Vegi. I run it out here in Boulder Colorado. My kit is from greasecar installed by Canola Conversions in Bennett Colorado on a 2000 E350. Had only one T connection break in the four years running it. Canola convertions replaced it for free with a brass one. Can't stress enough about filtering the oil. Developed a great system out here. Now I will be running a new system which has 4 fuel/oil filters that work together. Lasts longer and is cheaper filters. Heats up faster and less time running on diesel. Plenty of power running up and down I70 all winter long towing snowmobiles. It's messy but cheap fuel.
