| Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here. |
Suggestions on "all in one" centrifuge to buy
Hello
Im looking at a centrifuge set up that i can purchase and set up without a DIY approach.... besides containers and tubing which i know ill hafta set that up for myself. I have been looking at WVO designs centrifuge and Absolute Centrifuge. From some recommendations I am leaning to the "Absolute" centrifuge. This is for my business so money isnt a concern which is why im going away from the DIY as well as i dont have time to test n tune a centrifuge set up. I will be pushing 50-100 gallons a week (at the moment, possibly more) through this Anyone using the Absolute Centrifuge system or another system they like? Thanks for any thoughts and suggestions |
I have one but never used it
bought it as a package deal with a v3 and a bunch of other stuff.
Never used one but have read comments from many using both types of centrifuges & all was positive. Simple centrifuge is another good option. I would buy WVO Designs one only because it is cheaper. No matter which one you buy you will be very happy with it.
I have an older SimpleCentrifuge 2 piece bowl design and WVOdesigns inline heater. Perfect setup.
SimpleCentrifuge is coming out with a bowl design in October that will be more user friendly. I called them to order replacement seals and screws as I broke one of my seals, stretched another, and almost lost one of the screws in 40 gallons of wvo muck. They sent me all the seals and screws for free. They are also doing a trade up program when the new one comes out. Send in the old one and get $400 credit twards the new one. WVODesigns is cheaper because it is cast aluminum bowl from outside the US. Simple Centrifuge is Billet aluminum made in the US. |
^^^What Cashflow said^^^ Leon(WVO designs) knows what his "Made in China" centrifuge is worth. that is why he charges less for it. You will get what you pay for. It is a cast aluminum, inferior POS..... IMHO. On the other hand, if you are looking for an all "Made in the U.S.A" product, call Simple Centrifuge. All machined, billet aluminum rotor that is actually balanced. HEAVY cast enclosure and state of the art technology, so state of the art that WVO designs hasn't even been able to keep up copying their ideas! I also recomend NOT using an inline heater. Using a 6-10 gallon water heater will act as an appleseed processor, removing water and setiment before the CF. What some guys fail to realize when setting up a CF is this......Its NOT a garbage disposal. It is best suited for "polishing" oil, not to get the big chunks. Just my opinions, I could be wrong. |
1/8 the size of a 50 gallon is 80% of the 50 gallons price. Your paying for it to "BE" a water heater.
all very interesting - the process i had in my mind was to run my oil through a basic filter into a settling container - after letting it settle for awhile i would drain some of the oil out of the bottom - hopefully getting water and large waste chunks out and then running it through the cf - then after the cf running it through a final filter before using it
to vegginpsd - i have talked to several people about a water heater approach - could i run the oil through a rough filter into my container and then have that feed into the water heater then into a cf? then would i want a final filter after the cf? also i havent seen a set up using a water heater so im confused where the water and misc junk go inside the water heater ... as in how to i clean the water heater out off all the junk and how often - also with the water heater approach do you have anything pressurizing the water heater or how does the concept of the water heater work? some people have mentioned a heating element in the bottom of the water heater or is it pressurized and that helps separate the oil from the water and misc junk? thanks for all the responses everyone - theres so many filtration methods and im just trying to find the ideal set up to make the best quality oil end product - i would like to have a set up that removes water and large crap before the cf since i do see the cf as a perfecting element for the oil |
Here is a video that might sway you tward a Simple Centrifuge
I dont know why we are making such a big deal about where the centrifuge is made and the balance. It still functions great. I have an absolute.
