B5 biodiesel - Ford Powerstroke Diesel Forum
Bio-Diesel/Alternative Fuels and Supplements Bio-Diesel and related Discussion. Ask Questions and discuss what has worked for you here.
post #1 of 9 Old 07-21-2011, 09:09 PM Thread Starter
Metal Mulisha's Avatar
B5 biodiesel
Im new to the diesel world so sorry if this is a nooby question but will running b5 biodiesel mess up the fuel filter at all? I have heard of higher amounts of biodiesel causing clogged fuel filters. Will b5 do it?
2006 F-250 Lariat
Super Cab short bed
20% tint
20" LED light bar
Diamond eye 5" straight pipe
River City Diesel EGR delete
ARP head studs w/ OEM gaskets
Blue spring
SCT X3 xtreme street
Edge Insight CTS
Mag Hytec diff cover
7 inch Icon lift
20x10 machinedFuel Hostage rims
37x13.50x20 Toyo Open Country M/T
Metal Mulisha is offline
post #2 of 9 Old 07-21-2011, 09:13 PM
Nothing, stations around here have B20 at every pump. It's fine.
Austin G is offline
post #3 of 9 Old 07-22-2011, 03:40 AM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Bio doesn't actually "mess up" your filters. It actually cleans out your system, thus clogging your filters. Running only B5 though likely wont cause you issues...
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #4 of 9 Old 07-22-2011, 08:31 AM
tubular031's Avatar
yup what stroked_ny said. My truck is an 01 and I started running b50 to b100 when I had 160k miles on it in 08. Since my truck was always sipping on the tank there was not much time for crud to build in the system. I never had a clogged filter. I actually carried spares with me just incase and did not need them. Now if you have an 01 with 80k miles on it, diesel has had plenty of time to sit and Ill bet there will be lots of crud in there to break free and clog the filter.
Bio or not, its ALWAYS a good idea to have a spare fuel filter behind the seat.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #5 of 9 Old 07-22-2011, 12:50 PM
Galaxie's Avatar
WOrks fine.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #6 of 9 Old 09-10-2011, 08:09 PM
I am also new to the Diesel world. Just bought an '08 F-250 and as I read the owner's manual, it says not to use any more than B5 biodiesel. However, the stations around me all have between 5 and 20% biodiesel. What am I to do? Am I going to have to worry about replacing fuel injectors? Or will I just have to shorten up the maintenance schedule on my fuel filters?
j_schwindy is offline
post #7 of 9 Old 09-11-2011, 02:10 PM
Quoted: 3 Post(s)
easiest fix is get a 7.3
Early 99 crew cab long bed SRW
Vegistroke V3.
Support Grease Mafia on Facebook
erbilabuc is offline
post #8 of 9 Old 12-04-2011, 08:26 AM
baysic's Avatar
b5 and b20 is that the percentage of bio diesel and the b i take it is for the bio part? cause i did see a chevron had some bio deisel at the pump, and it should be ok for the tune as well?
baysic is offline
post #9 of 9 Old 12-04-2011, 05:57 PM
PGreenSVT's Avatar
I know my 6.0 loved running B99 so I can't imagine B5 or B20 causing any issue other than possible waxing when it gets cold. Depends on the feed stock what temp this happens at. I have known home made Bio made from Canola oil running at 0* F without a problem. On a newer truck there shouldn't be any problem with clogging the filter but it never hurts to have a spare on hand. Your injectors will really thank you. It's the best lubricity additive you can buy.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
